Maytag Washer I tried your solution replacing the hoses, but it did not work. The control dial will not advance to the proper setting. Any other suggestions?
  • mam8321 Apr 12, 2008
    You are wonderful! With the information you provided, my husband was able to fix the washer. He never knew about the pressure hose inside the washer case.
    Bravo!!!!!
    Genius:
  • 1,073 Answers
Not the water hoses that connect to the water fausets of the house to the machine, it is a pressure hose that is inside the washer case, it connects to the switch that you select low medium and high water level, it then connects to the tub of the washer hope this helps
Posted on Apr 10, 2008
Washer will work in Rinse or Spin settings, but not any wash settings
If you are doing the normal procedures and the water elimination function is working, you have power to the circuit board and controls. The circuit board wash cycle section is independent and aligned with the timer circuit, thus the Wash Cycle Controller has failed. All of the functions or options are one the one board and a replacement board needs to be purchased and installed.
Feb 26, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
I have a Maytag Ensignia washer that will fill with water and start working but will not advance to the next cycle without manually advancing the dial. once helped into the next cycle the washer works...
First you need to list the model number in order for me to figure out what type of washer it is then i can help you. The reason I ask is some Maytag Ensignia's come with electronic timers and some models have old style timers...
Mar 10, 2013 | Washing Machines
I have a Maytag washing machine and will not drain unless I reset dial to that setting. the model # sav3655aww
Yes there is a small motor just like in most wall clocks the gears strip or the gear bushing slips and refuses to advance the dial.
you have to replace the whole timer unless you know MacGyver microsurgery
Nov 27, 2012 | Maytag SAV3655A Top Load Washer
Maytag top load washer model LAT9235AAe will only run when dial turned to final rinse position.
HI. this is a fairly simply fix here. the timer mechanism is damaged. The timer motor is not providing proper rotation, that is required for forward advancement of the cycle selected. It should be replace asap, if possible.
Sep 06, 2009 | Maytag Washing Machines
My Washer will work at all. It acts dead
a small run of these actually had an out of balance switch and fuse assembly that cut power to the machine if it went way out of balance ,check and see if yours has one and replace the fuse at first but you may have to replace the entire assembly
Feb 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer will not fill
If it wont fill properly it sound to me me like a preasure switch. Take the control panel off and look at the load size selector switch (preasure switch). This has a hose connecting it to the wash tub. Follow that hose back to see if it may have some kind of blockage in the line. If not you may need to replace the switch.
Jan 26, 2009 | Maytag PAV2300 Top Load Washer
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
