I have a gemini mac 10 universal remote controller and a Toshiba tv but i don't have the codes. Can you help me with this.
5 Suggested Answers
SOURCE: gemini universal tv remote
Hi, I have the same remote (CL033 one) and I found these instructions http://klkl.co.uk/?p=13 and they worked great for me.
Posted on Nov 18, 2007
ctf1800
  • 4402 Answers
SOURCE: tv remote setup code for toshiba
Remote codes
http://www.remotecentral.com/index.html
Posted on Feb 22, 2008
SOURCE: universal cable company remote control codes
brighthouse remote code for panasonic amolifier to adjust volume
Posted on Mar 14, 2008
aprmaejun
  • 97 Answers
SOURCE: philips remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 22, 2008
  • 1550 Answers
SOURCE: I need the remote control
You can get code from the manual you got with the product .
If you dont have manual contact manufacturer to get the code.
Posted on Mar 04, 2009
I have a Gemini remote and a Symphonic TV (model # WF20L6) and am wondering what the code is? The remote only says Gemini on it. Help !!
Hello
Without knowing the exact model number of the remote, it will be difficult to locate the codes. Anyway, try thesed codes.
033/ 053/ 189
If your TV needs a four digit setup codes, you can try these codes.
0053 0189 0227 0456 0024
OK
Oct 23, 2011 | Gemini 1 Device Universal Television...
Need tv code numbers for gemini universal tv remote so i canprogram to my magnavox tv set
Code for your Gemini universal remoet to progrmme your magnavox TV are
080,120,130,190,270,300,0054, 0706, 0030, 1454, 1254
Thanx
Aug 05, 2010 | Gemini 1 Device Universal Television...
I bought the gemini universal remote control G401S but it didn't work when i tried the the brand search it changes only 2 channels can yo plzzzzzzz help me?
Hello
I have found Gemini's list of codes for a different model remote. I could not find your model but the models I found are identical to each other with their codes, so trying these should be worth a shot. Here are toshiba's codes:
TOSHIBA 140,200,210,220,440
Good Luck
Hope this helps and please don't forget to rate
-Chris
May 04, 2009 | Toshiba 27A33 27" TV
Need codes for philips universal remote on a toshiba TV
i don,t know the code to this remote it is a ge universal remote
Jan 06, 2009 | Philips Universal PH301S Remote Control
Gemini Universal Remote - TV and DVD codes
I'm just calling the Funai company and buying a new remote.
Aug 18, 2008 | Gemini 1 Device Universal Television...
Codes list required for Gemini G610S multi remote
Try 230, 231. 232, 233, 248 for the VCR.
Try 009, 011, 019, 024, 025, 027, 028, 051, 062, 068, 107, 115, 120, 131, 132, 139, 167, 169, 171 for TV.
Sorry - cannot help with DVD.
Len
Jun 06, 2008 | Gemini 1 Device Universal Television...
Gemini universal tv remote
I lost a few manuals myself. Gemini Universal Remote Control Programming Codes ------------------------------------------------ 1.Locate the 3-digit brand code from tables below. 2.Press and HOLD the RCL and ENT keys simultaneosly, until the red indicator turns on (3-4 sec) 3.Select the type of device you are programming by pressing the TV, VCR, CTV or AUX key. 4.Enter the 3-digit brand code number. If a valid code was entered, the indicator light will go off. 5.Test your Gemini remote,by pressing PWR key. Repeat 2-5 with new code number if not responding. Autosearch Instructions: If your remote has an auto search on it. 1. Turn ON the device you wish to program the Gemini to operate. 2. Press and HOLD the RCL and ENT keys simultaneosly, until the red indicator light turns ON. 3. Select the type of device you are programming by pressing one of the TV, VCR, CTV or AUX mode keys. Now enter one of the following device type search codes: TV-990, VCR-992, Cable-994. 4. Aim the Gemini at the device and press the red PWR key. If your device turns OFF, press the appropriate device mode key again,(TV,VCR,CTV or AUX),to lock in brand code for that particular device and exit from the programming mode. 5. If the device doesn't respond, press the VOL"+" key once to advance to the next brand code. Now press the PWR key again. Remember to immediately lock in your code when the component turns OFF by pressing the proper mode key. Continue repeating steps 4&5 until your device turns OFF. I hope this helps you out, Good Luck to you. TV Codes ADMIRAL 400,530 MITSUBISHI 020,160,180,190,230,240,580 AKAI 160,240,550 MTC 140,180,300,310 AMARK 390,590 NATIONAL 010,270,420,510,570,610 AMSTRAD 110 NEC 180,190,240,300,310,580,620 ANAM 170 PANASONIC 010,270,420,510,570 ANAM NATIONAL 420 PHILCO 080,120,130,180,270,240,270 AOC 180,240,300 300,390,450,490,540,590 BELL&HOWELL 530 PHILIPS 080,120,130,180,270,300,450 CANDLE 060,080,300,310 490,540,560,590 CENTURION 190,580 PORTLAND 390,590 CITIZEN 060,080,140,300,310,390 PROTON 240,390 CONCERTO 310 QUASAR 010,420 CONTEC 170,260,470 RADIO SHACK 070,170,190,390,410 CORANDO 390 RCA 090,180,240,400,500,600 CORONADO 590 REALISTIC 070,150,170,190,390,410 CRAIG 170 SAMPO 190,300,580 CURTIS MATHES 030,140,190,300,390,470 SAMSUNG 140,180,190,300,310,390,410 590,650 580,590 CXC 170 SANYO 200,430,460 DAEWOO 180,340,380,390 SCOTT 020,190,390,580 DAYTRON 190,390,580 SEARS 020,140,190,200,210,390,430 ELECTROHOME 160,390 440,460,590 EMERSON 020,110,150,170,240,280 SHARP 000,050,070,390,590 330,390,470,590,650 SONY 350,550,640 ENVISION 300 SOUNDESIGN 080,240 FISHER 200,460 SSS 170,180 FUNAI 020,170 SYLVANIA 080,120,130,190,270,300,360 GE 010,040,290,400,420,630 450,490,580,630 GOLDSTAR 180,190,240,310,390,590 TATUNG 420 HITACHI 100,260,310,320,390,590 TECHWOOD 310 INFINITY 270 TEKNIKA 020,060,080,140,160,170,180 JBL 270 270,310,390,480,530 JVC 030,250,370 TELERENT 390,530 JC PENNEY 040,180,190,240,290,300 THOMSON 400 390,400,440,500,630 TMK 240,310 KLOSS 490 TOSHIBA 140,200,210,220,440 KMC 390,590 TOTEVISION 390 KTV 170,240,390,590 UNIVERSAL 040,290 LLOYTRON 390 VIDTECH 180 LODGENET 530 WARDS 020,040,070,120,130,180,190 LOGIK 530 240,270,290,300,390 LOGIX 530 YAMAHA 180 LUXMAN 310 YORX 190,580 LXI 000,190,210 ZENITH 520 MAGNAVOX 080,120,130,190,270,300 390,450,490,580,590,630 MAJESTIC 530 MARANTZ 160,240,300,450,490 MEMOREX 530 MGA 020,160,180,190,230,240,300,580 VCR Codes AKAI 002,052,112,202,372,402 MULTITECH 072 AMSTRAD 072 NATIONAL 272 ASA 022 NEC 202,252,292,302 AUDIO DYNAMICS 202,292 NORDMENDE 202 AWAI 392 PANASONIC 272 BROKSONIC 282 PENTAX 332 CANDLE 022 PHILCO 272 CANON 272 PHILIPS 272 CITIZEN 022 PIONEER 252 CRAIG 092,182 PORTLAND 232 CURTIS MATHES 272 QUASAR 272 DAEWOO 062,232,342 RADIO SHACK 022,072,092,142,152,182,272,312 DAYTRON 232 RCA 032,182,272,422,452,492 DBX 202,292 REALISTIC 022,072,092,142,152,182,272,312 DUAL 202 SABA 202 DYNATECH 072,142 SAISHO 242 ELECTROHOME 022 SALORA 212 EMERSON 042,072,082,102,112,132 SAMSUNG 172,182,342,412 192,242,282,472,482 SANSUI 202,252 FERGUSON 202 SANYO 092,312,382 FINLUX 072 SCHAUB 202 FISHER 092,322,332 SCOTT 132,212,242,342,432 FUNAI 072 SEARS 022,032,092,162,312,322,332 GE 182,272,422 SHARP 142,222 GOLDSTAR 022,292 SONY 122,252,352,362 GRAETZ 202 SYLVANIA 212,272,452 HARMON KARDON 292 SYMPHONIC 072 HITACHI 032,072,202 TASHICO 022 INSTANT REPLAY 272 TATUNG 202 ITT 202 TEAC 072,292 JCL 272 TEKNIKA 022,072,272,502 JENSEN 202 TELEFUNKEN 202 JVC 012,202,252 THOMSON 202 JC PENNEY 022,032,272,292,302 THORN 202 KENWOOD 202,252,312 TMK 042 LLOYD 072 TOSHIBA 162,202,212,342 MAGNAVOX 272,452 TOTEVISION 022,182 MARANTZ 272,292,452 UNITECH 182 MARTA 022 VECTOR RES. 212,292,302 MEI 272 VIDEO CONC. 302 MEMOREX 022,072,272 VIDEOSONIC 182 MGA 022,192,212 WARDS 022,072,142,182,222,272 MINOLTA 032 YAMAHA 202,292 MITSUBISHI 022,192,212,442 ZENITH 122,252,432 MTC 072,182 CTV (Cable TV) Converters Anvision 104 Realistic 504 Cablestar 104 Regal 444 Diamond 444 Regency 164 Drake 144,284 Rembrandt 474 Gemini 244,274,474,534 Samsung 094,374,474 General I. 004,034,044,204 Scientific Atlanta 074,524 GI/Jerrold 004,014,024,034,044,204,234,244,354 Sprucer 494 GI/Starcom 394 Standard Component 474 Hamlin 424,434,444 Starcom 014 Hitachi 414 Stargate 484 Kate Vision 474 Sylvania 114 Macom 184,304,324 Tocom 194 Magnavox 054,104,124,344 Toshiba 184,264 NSC 474 Tri-Vision 124,234,354,364,384 Oak 294 Unika 154 Panasonic 334,494 United Cable 014 Paragon 454 United Satellite 224 Philips 054,104,124,134,174,214,254 Videoway 314 Pioneer 064,084,094 Viewstar 054,104,124,134,174 Pulsar 484 Zenith 144,184,404,464,514 Randtek 104
Jul 01, 2007 | Gemini 1 Device Universal Television...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
