Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Cannon sd400 power shot
LCD screen is white with a feather image diagonally across it.
This screen displays whether in shoot or play mode.
I can take a picture with the range finder but only see the white screen
with feather image in LCD.
  • Lucky1925 Apr 11, 2008
    Thank You,
    I contacted Cannon and they are offering a refurbished 700 series for $100 plus $10 handling. I am thinking of doing that.
    What do you think?
  • mc11 Apr 27, 2008
    I think I may have the same problem, although I don't think the camera was dropped, it has a line across the screen and what looks like an ink blot. I will look at taking the camera apart and see if it is worth getting a replacement screen.
  • 22 Answers
Sounds to me like you have a broken LCD screen. This is unfortunately very common in the SD200, SD300, and SD400 cameras. Because an LCD display is made up of a few sheets of very thin glass, they tend to break rather easil and then the "dye" leaks out, hence your feather pattern.
If you feel up to taking your camera apart, you can purchase a replacement screen on eBay for around $60-$80. If you don't feel up to trying to replace it yourself there are people on eBay who offer repair services for broken LCDs and they typically charge between $80-$100.
Posted on Apr 11, 2008
SOURCE:
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
Screen damage?
this is a clear problem of total death of the LCD screen.
you will have to replace the full screen.
no other go.
thank you
Aug 12, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Outdoor pics completely washed out Cannon S5 IS Power shot
Try going into the review menu, choose setup and then choose 'reset all' This should re-set all shooting settings to automatic and solve the problem. If that doesn't do the trick, your sensor is probably damaged - not good news - sorry
Jul 25, 2010 | Canon Cameras
My cannon power shot sd600 viewer doesnt turn on
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD screen on and off to save batteries. You would then use the optical viewfinder in its place. Try pressing this button one more time to see if it turns back on.
Oct 13, 2009 | Canon PowerShot SD600 Digital Camera
No image preview
You would need to buy a new lcd for this would be the obvious soltuon in this case. Do not shoot the messanger!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Picture display result
Which mode are you shooting in?
You may have adjusted the exposure compensation so everything is washed out.
Whatever the cause, your images are overexposed. Try shooting in auto and the camera should take over the settings, but if you are in other modes, check your shutter speed, aperture, & ISO also. These are all things that can cause too much light and wash the picture out/OVEREXPOSE.
If you have any other questions or can give me more details, just ask!
Hope this helps!
Jun 01, 2008 | Canon PowerShot A460 Digital Camera
Display Cannon 630 powershot
Thanks for your reply
Out of frustration I was sitting looking at the camera and thought to try all buttons and see what hapenned. On the righthand side of the camera in the bottom left position is a button marked display. Normally during live display mode, you can either switch the screen on or of by pressing this button (to conserve the batteries). If the camera is powered off and then on again, the screen automatically is in live display screen active mode again. For some reason my display remained off. When I depressed this button once after switching the camera on - voyla! The display worked again in live viewing mode. I do not know whether the screen is supposed to stay in the off mode when powered down in live display off mode even when it is switched off and then back on again or not, but the previous times I did, it was automatically on when powered up again.
So, before repairing your camera, please make sure that it is actually broken - refrain from making a fool of yourself like I did.
Thanks once again for your support
Regards - notsobroken
Feb 12, 2008 | Video Cameras
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
152 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
