Question about GE WBSR3140DW Top Load Washer
Stuck between cycles
My GE washer is stuck between cycles and just hums. I'm afraid it will burn the motor up.
What should I do?
Thanks, Bob
    Champion:
  • 207 Answers
It seams to me that your pump and/or water outlet is clogged. Humming noise comes from the water pump as it tries to pump out water. You should unplug the machine, unclog the outlet pipe if it is clogged. While you're at it check if the filter in front of the pump isn't clogged too.
Posted on Apr 11, 2008
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
Motor hums but won't start
chances are the pump is blocked as well and unable to spin
Nov 03, 2013 | Dishwashers
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Ge washer wont agitate and makes a humming noise when in agitate cycle
That means the motor has shorted out if it is not spinning. The brushes inside the motor may have overheated and stuck. You can try tapping on motor inside wash machine to see if it will free up.
Jun 17, 2009 | GE WDSR2080D Top Load Washer
Washer fills, but cycle doesn't start
This is motor failuer. replace asap. the smell is the motors copper windings heating up the internals of the motor Housing.
Jun 02, 2009 | GE 24 in. GSD4030Z Built-in Dishwasher
Does'nt cycle properly
Hi.
this is a failed timer device. By replacing the timer control module it will eliminate these issues you are having and ur problem will get solved...
thank u
rate me!!!
Jun 01, 2009 | GE WBSR3140DW Top Load Washer
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Humming and not filling?
had the same problem this morning, turned out the pump on the drain side had frozen, took it apart, and broke free the fan, humming stopped, washer back up and working.  Its two screws to the bottom of the washer, two electrical connection (white and black) two hoses to undo, and three screws on the pump itself, after actually committing to doing it, only took about 10 minutes.
good luck
Oct 13, 2007 | GE WSXH208A Front Load Washer
GE WBSR3140DW Top Load Washer Logo
139 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
