Question about Panasonic Workio DP-2330 Printer
DP-2330 on Vista
Experts,
please find below a problem i faced after the advent of windows vista to our network.
Spooler subsystem App stopped working and was closed
A problem caused the application to stop working correctly. Windows will notify you if a solution is available
Windows can't open Add printer. The local print spooler service is not running. Please restart the spooler or restart the machine.
  • naji84 May 17, 2008
    i have the same problem any advices on how to recify the problem
To start your spool service type spoolsv.exe in the run box.
Posted on May 31, 2008
What is Spooler subsystem app?
I would uninstall printer software and reinstall with new downloaded software.
Dec 24, 2014 | Computers & Internet
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
Need drivers for panasonic dp 2330 printer
You can download your driver here: http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11201&catalogId=13051&itemId=88287&catGroupId=13843&surfModel=DP-2330&displayTab=R
Just click on the driver download & select the driver for vista. Hope this helps & please remember to rate my answer. Thanks.
Jan 09, 2009 | Panasonic Workio DP-2330 Printer
Error 1068 on vista print spooler stopped
Please follow the below given steps to remove the dependencies.
1.Click start icon.
2.Click on All Programs.
3.Click on Accessories.
4.Click Run.
5.Type cmd and hit enter.
To remove this dependency all you have to do is open the command prompt and type in the following command:
Please type Sc*config*spooler*depend=*rpcss (put spaces where the (*)’s are.
When you hit enter you will get this message:
Sc config spooler depend= rpcss [SC] ChangeServiceConfig SUCCESS
Now please restart the computer and try to install the printer.
Aug 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Spooler sub system app??
The issue occurs because of a corrupted printer driver installed and because of the Vista OS that keeps updating.
-Open up c:\windows\system32\spool\PRINTERS
-Delete the contents of the directory (not the directory).
-Restart the print spool service. (service.msc)
Jul 08, 2008 | Datacard SP55 Printer
Spooler subsystem has stopped working
if u not getting print due to " Spooler subsystem app has stopped working " Error then go to Run---->type "services.msc"------->u get services console----------->select "Print Spooler"go to propriety ---------->check start-up type ------>if it is disable select automatic &press start for get start (if it is alredy started then get service stop & after get start with automatic )
if there is problem in printing due to Spooler it should be resolved
if this information is useful for u please Rate me..........
Jun 22, 2008 | HP Color LaserJet 2600n Printer
DP-1820E shutdown the Print Spooler's Windows Service
Had same problem. Downloaded Standard GDI printer driver from http://www.bayshoreoffice.com/drivers/ dated April 11 2007 and overwrote old driver with the updated one (ver4.2 I think) and printing to DP-1829E was restored. Strangely PCL printing won't work at all!
May 16, 2008 | Panasonic Workio DP-1820E Copier
HP print spooler problem and error 1068. Want my printer back!!!
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn’t work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click “Print Spooler”. Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you’re lucky, this might be all you have to do. Still doesn’t work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer’s software from the manufacturer and reinstall it. get more information for printer spooler error .Hope this helps you.
Mar 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Linksys WPS54G
Hi Scott.
Make sure your firewall is set on the Vista to allow the network discovery. Follow this link, click on Networking>File and printer sharing. It will tell you how to setup Vista to work with printer
http://windowshelp.microsoft.com/Windows/en-US/networking.mspxsharing.
This link should help, too. It is just for your Printe server.
http://www.experts-exchange.com/OS/Microsoft_Operating_Systems/Windows/Windows_Vista/Q_22960040.html
Good Luck!
Jan 05, 2008 | D-Link DP 300U (DP-300U) Print Server
Panasonic Workio DP-2330 Printer Logo
112 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
