Question about Maytag Dryers
Need vent for drier to go out window window is a doublehung do anyone make something for this that is airtight my window is about 24 wide by 32 high or any suggestions would be a great help thank you mike ruch
How to vent exhaust of dryer out side rather then from back
get a flex hose and bend it around make sure it isn't pinched and vent that way, you can get at the hardware store
Jan 03, 2016 | Dryers
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
Hisense reset
The outside vent must be OPEN to allow the appliance to get the needed air. In the heating mode of a heat pump, the outdoor coil becomes the condenser. Open the outside vent!
Nov 25, 2013 | Amana Heating & Cooling
My dryer is leaving burn marks on my clothes . burn lines are typically about 2in long 1/2 in wide and all heat settings leave the burns
thermostat poss faulty or air vents blocked (i have seen a drier where the owner never cleaned the outlet vent and you could heat the house almost....
Feb 16, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
What is the vent on the outside back of the cab? passenger side between the cab and the bed
Hello. That vent is there to release air pressure from inside the cab when you close the doors with the windows rolled up. If you open the passenger door and then close it with your hand by the vent you will feel the air coming out. The truck is so airtight the vent makes it easier to close your doors.
Feb 06, 2010 | 2000 Chevrolet Silverado
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Possible restricted drier
Before you start checking pressures, you need to make sure that the unit is clean inside and out. You also need to know what the ambient temp is outside so you know what the pressures should read. Without this information, your info is useless to me. You need to know what your saturation temp is to determine if the head pressure is too high or too low. If the outside unit is dirty, you will have a high head pressure and low suction pressure. If the inside is dirty, you will have a high suction and a normal to low head. My advice to you is to clean first and then start checking temps and pressures. Otherwise you are spinning your wheels.
Mar 31, 2009 | Heating & Cooling
Not heating
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Did you check the outside vent opening!If the screen outside that prevents small animals from entering gets even half way cloged, you will loose heat!!!
Otherwise this is a situation that you will need service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 24, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer heats up but isn't drying properly
yes it does something is blocking your vent either its all coiled up behind the drier or something i need to ask a few questions go out side and look at where your drier vent has a hood make sure nothing is blocking it from opening it has a little round door on it ive seen some that have little plastic screens on them that gets clogged the screen is there to keep critters from building nests in the vent line then get a flash light and look over the back to see if the vents folded over mashed etc to find out if its a vent problem take your vent loose dry a load and see if it goes back to normal if all that's ok get back to me and we will clean the drier i need to know if your lint screen is on top or in door and your model #
Jan 02, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
