Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
Toyo stove, Lazer 30 model
The heater ran out of fuel.  We got new fuel, tried restarting.  After 3 tries the error E22 come up on the heater and stated that we needed to call a repair person.  the error will not allow us to try to start the heater again with out tech support.  What can we do?  We live in a remote area of Alaska.  Tech support is not available.
    Problem Solver:
  • 17 Answers
EE22 is a lockout code.
Unplug unit for 30 min.
You need to findout why you still get EE2 or EE6
Check fuel and filter
Still have problems call me I'm in North Pole
Dave 4889179
Posted on Apr 07, 2010
Steps to fix a EE2 Code on a Toyo 30?
It is a fuel issue, when opening that valve with the fuel strainer out. If your fuel was right it would gush all over. More fuel or lift tank. I hope you have a filter at the tank, if so change the element. (its cheap and good preventive maintance.
Any other questions call me
Dave
Total Toyo
907-488-9179
Nov 19, 2012 | Rinnai Toyostove Direct Vent Heater: Laser...
Lazer 30 error 22 on panel
The stove quit three times with an ee2 message. The stove is trying to save you from flooding. You may have a fuel problem that is causing the ee2 problem. After three time the stove locks out and won't let you try again. Find out whats up with the fuel. Unplug the heater for 20 minutes and you will be able to try again. Also make sure the igniter is getting hot. Two red wires going into the burner should get hot.
Tom
Sep 25, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My toyo lazer 30 won't start, and the EE2 problem comes up.
With an EE2 message you have a problem with the stove igniting during start up. If you continue to try you will end up with an EE22 and the stove will be locked out. If so, un plug for 20 minutes. While you are waiting check out you fuel system. Low fuel, no fuel, dirty filter on tank and stove. Be sure to bled the air off the top of the filter when you change it.
Keep us posted.
Tom
May 14, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a Toyo Lazer 30. Often times it doesn't run for a few days (I also use wood heat). So then when I go to start it up (after a few days) or if the thermostat tells it to start, it might run for a few...
Ticking is a sign the heater is not getting anough fuel to keep running. Check your manual and see if there is a valve inside your heater that controls fuel flow. Make sure it is open all the way. Also check to see if you have the valve on your fuel tank open wide enough to allow fuel to flow like it should. Another tip. Instead of turning your heater off all the way when you are using wood heat, why not just turn the temp on the heater lower then you know your home would get to with wood heat running. Adjust the temp to where you need it when you want the heater to run. (That way your heater stays primed.) The heater doesn't draw that much electricity. ;)
Hope I have helped.
Diana
Nov 12, 2009 | Rinnai Toyostove Direct Vent Heater:...
Laser toyostove will not ignite
Zen,
When you ran out of fuel the filter trapped some air in the very top. You need to loosen the fitting on the fuel line right at the filter and let the fuel run of a minute. This will clear the air from the top. On the way out to the filter unplug the stove. Leave it unplugged for 20 minutes. This will clear the EE22 message. Now you can restart your stove.
Tom Hawkins
hawkins111@gci.net
Apr 07, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Need a service manual for laser 30 toyo stove
Remove the flex hose from the back of the stove. If there is a small hole in the back of the stove, stick a pencil in there and spin the motor. Try to start the stove. If the motor won't spin at all or if it spins freely and the stove still shows an EE8 you need a new motor.
You or your local dealer can change the motor in 30 minutes.
Tom Hawkins
Bethel, Alaska
Jan 15, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo stove laser 30
EE22 means that your Toyo failed to ignite 3 times in a row. You need to unplug it for 30 minutes to reset the circuit board. Then plug it back in, push the red reset button on the right hand side in the little hole towards the back and push the Power button. Your Toyo should ignite after that barring some other problem caused by running out of fuel.
I am assuming that you ran out of fuel which caused the EE2 error code originally. Sometimes, when you run out of fuel you can get water, ice, debris in the fuel line causing an obstruction or limited fuel flow. You may also get an air lock. You may need to crack the fuel line at the back of the Toyo where there is 3/4 nut and bleed the line. If you see no fuel or a small quantity of fuel then you will need to thaw and/or purge the fuel line in order to get fuel to your Toyo's fuel pump.There is also a screen in the sump which can get plugged with rust, debris from the bottom of the fuel tank so you may need to clean the screen in order to get fuel to the pump.
Nov 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Have you tried to disconnect the power and then reset the clock. If it doesn't fire after the first time push reset for a period of one second. If that doesn't work email me back and i will call rannia tech support and find out some more information on the heater. What kind of fuel are you using
Apr 08, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Lazer 56
Hi EJAKFbanks,
I believe by your description and my 8 years experience with Toyo Stove repair that you are missing part of the firing sequence. The firing sequence for a Toyo Stove L 56 is to blink on the burner light for 7-9 minutes, then it clicks up to the medium light (amber-yellow color). The medium light blinks and that is when the fuel pump kicks on and starts to pump. If the stove ignites, the medium light will glow for a second and then drop down to the low light (green) The low light will burn for awhile and at this time you will see a blue flame in the newer heat chamber models or a red glow, and perhaps some blue flame in the older heat chamber models, then the stove will kick up to the medium light for a bit, and then to the high light. An EE6 error code will show only when the flame is extinguished after actually taking place and a burn did occur in the chamber on low. An EE6 is usually one of 2 things: 1. There is an inadequate fuel supply for the stove to maintain a low cycle burn, or the medium, or high. Each cycle consumes more fuel than the prior one. Inadequate fuel supply can be due to a restriction in the fuel line such as icing like cholesterol in a persons arteries, or a plugged sump screen, blocked fuel line or filter, too low a quantity of fuel in the tank, or a fuel line that is not all gravity feed, as in, the fuel line runs down, down, and then up a few feet to get to the Toyo. In that case, the fuel has to rely on head pressure to get to the stove. Head pressure is the atmospheric pressure pushing on the fuel in the tank to force it up against the earth's gravity forces. Solution: You can find any restriction in the line, replace the filters, clean the sump screen, put heat on the fuel line to thaw any icing blocks. 2. An EE6 can be caused by a carbon chain developing from the burner ring, flame sensor or chamber wall to any metal part in the burn chamber. A carbon chain essentially "shorts" out the ground for the unit and the Toyo will shut off on EE6. Solutions:You can bang the side of the Toyo (Old frustrated Alaskan solution) which really just jars the carbon chain loose, clean the flame sensor, clean the fuel nozzle with a straight 3 inch wire, and stick a screw driver in the igniter (red wires) hole and rattle it around real good (another old Alaskan trick). Often, those three things will get your stove running again if it is a carbon chain. The problem will likely occur again, but it will buy you some time until you can get a tune-up done. Most likely, you need a tune-up. Question: When was your last tune-up? Toyo's should be tuned up every 2 years. Tthe book says every one year, but in my experience, every two years is the best bang for the customers buck. The three year mark usually begins showing signs of metal fatigue in other parts of the burn chamber/heat exchanger system so the costs rise a little each year, unless you are a lucky Toyo owner and for some odd reason, your stove can go 3 years between cleanings without any ill effect. If you get your stove running, run it hard on High for about 2 hours to clean and burn all the carbon out. Good Luck! toyotech, North Pole, Alaska
Feb 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Exhuast smell(odor)
no, because the whole combustion chamber and piping is a closed system with the exception of the intake and exhaust which is a double walled pipe. you might check the tightness of your K-1 fuel line or look for leaks under the filter compartment where the solenoid pump is located. the fuel goes into the chamber via a small copper line with a silicone gasket under the gland nut.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
474 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
