Open the door!
Been doing a lot of clothes today?
Do you use more than a teaspoon of HE soap?
Washer been growling like a grizzly?
Those are signs of a overheated hall sensor.
These machines only use a gallon of water.
Any overage of soap will cause a suds lock.
The motor will try and FIX it by dumping extra water in and doing more work. Till finally an LE error will be declared.
If you are confident you are not overdoing the soap thing then you need to take a look at the wiring between the control and motor. It is a strong possibility the harness connection has vibrated lose OR you have a broken wire between the control and motor. If you want a service manual let me know.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I just ran a load of laundry and "LE" came up on my screen and the front load door won't open! What does "LE" mean? And how come my door won't open? Thanks.....Gloria
