I have no sound from my big screen tv I have pushed every button on control and cannot figure out why no sound any suggestions?
    Scholar:
  • 170 Answers
What is your model number?
Posted on Apr 10, 2008
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Have good picture, but big black square in center. Tv is a friends who pushed some button and messed up the picture. He said he was messing with the caption button.
Yes it sound like the caption screen, you may have a c.c or display button on your remote. But you will always find it in the menu, depending on your tv brand it may have different locations but its there.
Hope this will help.
Please do not rate this answer(unless it helps) as it is only a suggestion.
Dec 03, 2009 | Televison & Video
I have a 50 inch lg plasma tv and the picture is to big.
Ok take your Vizio remote control go to the Lower section of the buttons and look for the - Zoom + button than decrease the zoom.
Jun 19, 2009 | Vizio GV42L 42 in. LCD Television
No power Mitsubishi Big Screen
Sounds like the power supply went bad. Repeated on/off pushing of the buttons causes the set to go into shut down. If a part is marginal this is when it'll go bad. Usually a bad power supply part and will need professional repair. Please rate!
Mar 26, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Damn TV....why doesn't it turn on when you push the power button??
Good Day, U-Fix- it;
Try this; CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB. 2. CHECK R529 .82 OHM 1/2 WATT OFF PIN 4 OF THE FLYBACK. IF OPEN CHECK C411 2200 UFD @ 35V AND IC 451 PART # 270P064020. ON THE MAIN PCB.
CHECK IC700 PIN 4 (AC-OFF) FOR 0 VOLTS DC, IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. 2. CHECK FOR 4.7 VOLTS DC AT CONNECTOR RF PIN 3 AND 4 ON THE SIGNAL PCB IF LOW SUSPECT PROBLEMS WITH THE SWITCHES/BUTTONS ON THE CONTROL PCB PART # 935D394001.
Good Luck, big IRISH.
Apr 29, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Big button remote rcr 4258
does not have all the codes for every product,
Please give me the model # for the cable box -scientific Atlanta and the model # for Magnavox T.V.
also goto www.replacementremotes.com (336)969-1842
They will find you REPLACEMENT remote control CODES, not remote control
Apr 12, 2008 | RCA Universal Remote Control
50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Mar 17, 2008 | Televison & Video
Omnitech jumbo universal remote control and vizio hdtv
I have a solution but it is too much info for this tiny screen they have, and there is no support for photos1.gif. So, unfortunetly I have to send you to my photobucket account where I posted scanned pictures1.gif of the "Acual Manual" I hope the website doesn't get banned. Here are the five pages you'll need to set up your giant remote:
http://i162.photobucket.com/albums/t241/swestside/5.jpg
http://i162.photobucket.com/albums/t241/swestside/4.jpg
http://i162.photobucket.com/albums/t241/swestside/3.jpg
http://i162.photobucket.com/albums/t241/swestside/2.jpg
http://i162.photobucket.com/albums/t241/swestside/1.jpg
Jan 02, 2008 | Big Button TV Universal Remote
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
