Question about Toshiba 27D46 27" TV
Toshiba 36" flat tube tv
No picture but can access the menu and can hear a sound
  • 54 Answers
You have problem in video output, sometime it happen when the CRT socket has currusion or loose connection.
Posted on Apr 11, 2008
No sound on toshiba 36 tube TV
Check its speaker/s. If it is OK, the audio output IC should be checked.
Jul 14, 2012 | Toshiba 36A43 36" TV
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
I have a Toshiba 36"
Resolders the FBT-(flyback tranformer).Resolders the video board connections sockets holes,that the board connected to the CRT-(tv tube).Plug in the tv,to have power to the tv,take out the tv video board,for exposer of the CRT-(tv tube).Take an electrical wire with a good insalation in it,grounded to the tv steel frame some where.Take the other end of the wire go toward the open high voltage CRT-(tv tube).U will hear a pop sound,than ur tv CRT-(tv tube) is a 100% clean out of contaminations or u will hear a deeing sounds only,mean the tv CRT-(tv tube) it is to old to pop anymore,just let tv deeing sounds going on for like about 20 mins to rejuvenated the old CRT-(tv tube).After this repluging the tv video board for a tv signal and readjust the button on the FBT-(flyback tranformer) that said focus to fix the CRT-(tv tube) focus problems.
May 01, 2011 | Toshiba 36A40 36" TV
I have a Sony Trinitro 36" about 8 yeras old. When I first turn it on, I can hear the sound but the picture goes in and out a few times before it stays on, now it is doing it every once in a while during...
Its a good bet that the picture tube is going bad. Thats the classic symptom of a failing tube. The tubes if available cost more than new tv's.. Sorry
Aug 11, 2010 | Sony Televison & Video
Tv keeps flat lining and shrinking picture
If this is a crt tube tv. Your vertical ic is loosing its connection with the board. Better to quickly resolder it or reflux it with a new lead. Before the IC fail for good.
Apr 28, 2009 | Toshiba 36AF43 36" TV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Toshiba CF36G40 36" TV Problem
IO board has bad solder joints or is bad if you tap the outside firmly it will come on for a while
May 28, 2008 | Toshiba CF36G40 36" TV
Click click repeatedly faded then red blinking light
Go to the video menu and turn the color control to minimum. Determine if you have a black & white picture or is it green & white. If the picture is greenish, you have a problem in the screen circuit or possibly a bad picture tube. If the black & white is ok then I would suspect a problem in the chroma circuit such as a bad video jungle IC or a crystal. However, because your set had a red blinking issue prior to your existing condition I would lean towards the picture tube as the source or your troubles. You can try a simple test to determine if you have an intermittant short . Take the back off the set, and with the insulated end of your screw driver, very very lightly tap on the neck of the picture tube near the socket. If you see green flashes or hear loud snaps in conjunction with your taps or the green tint goes away, chances are the tube is the cause. If so, you might try installing an isolation transformer on the picture tube. Good luck
Nov 29, 2007 | Toshiba 36A61 36" TV
No picture, buzzing sound
It sounds like the horizontal output transistor may be shorted....Can you feel any static charge on the face of the pix tube?
Nov 15, 2007 | Toshiba 36A43 36" TV
Power but no picture on a toshiba 36a61 36" tv
could it be the socket wirings was loose check and retightened. more help....dnlsabangan@yahoo.com
Nov 09, 2006 | Toshiba 36A61 36" TV
Toshiba 27D46 27" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
