Question about Garmin Nuvi 660 GPS Receiver
Repair how can i delete the delete arrow is not working when i put a street number i can not remove it
I do not see how the delete arrow could possibly malfunction. Try recalibrating the touch screen. Settings > Display > Touch Screen.
Posted on Apr 16, 2008
How to delete a phone number
- Find the number first (select the "book" icon). Use up and down arrows to get to desired number.
- When you are at the number, select "menu."
- Use up or down arrow until "erase" shows. Press "select."
- Use arrows until "Yes" shows. Press "Select"
That should do it.
Apr 13, 2015 | Panasonic KX-TGA106 Cordless Phone 1 x...
How to delete a county in my midland WR120
The way I did it was to unplug the power supply and remove the batteries for a minute, this cleared all the settings. Put it all back together and then reset station.
May 22, 2014 | Midland Radio Midland WR 120 - Weather...
How to delete favourites
I'm not sure what your green arrow is. What does it do when you click on the arrow?
Apr 27, 2013 | Computers & Internet
Google maps: street views keep going to a split screen with street on top and satellite on bottom. Also street views in full screen mode disappear after a second and the split screen mode reappears.Very...
When you go into the split screen, and you don't want to be there, just click the little arrow in the lower right hand corner (the arrow pointing down and to the right). This will reduce the bottom map portion into a small overview box in the lower right portion of the screen. It only takes a second to get out of the split screen that way. To get back into split screen, click the arrow in the upper left corner of the overview box (the arrow pointing up and to the right).
Aug 15, 2011 | Computers & Internet
How do i load favorites into my tomtom 720.please set out steps
Depending on the operating system of your TomTom you should be able to tap the screen then tap the forward arrow until you see "add favorite". Tap "add favorite" then tap "address", then tap "street and house number". Type in the city. This will bring up a screen with several cities on it. Select the city you want, then type in the street name. the next screen will let you put the street number in. tap done. Tap OK on the next screen.
Nov 15, 2009 | Tomtom GO GPS Receiver
How do we remove an extension from a hunt group in a Norstar Meridian M7310 telephone?
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool2.gif on.
Press the next key 6 times (bottom right arrow) .
The display should say System Prgrming.
Press the show key (top right arrow)
The display should say Hunt groups
The display should say Show Group:
Enter in the group number of the member that you wish to delete.
The display should say Member DNs:
The display should show members for that group.
Scroll to the member you wish to delete.
Press the Remove soft key.
Press the heading key(top Left arrow) till the display says Show Group: again.
Enter in the group number you wish to to change the deleted member to
The display should list the current members of that list
press the Add soft key.
enter in the DN of the member you wish to add
Select Appr & Ring setting for the hunt group member
Press the release key when finished
Sep 30, 2009 | NorStar Meridian M7310 Phone
Updating a Group Fax
Assuming the group name will remain the same, you can edit the Sender's name and/or phone number by doing the following:
  1. Go through the procedure to Add a Contact or number
  2. When you reach that Contact, you can edit by pressing the < key to move through the name or number
  3. Press Delete key to remove the name and re-insert the name/ same process for editing the number
The process is as follows to get to the option you need:
  1. Open all three one-touch dialing panels
  2. Press Data Registration
  3. Use up down arrows to get to Add. Registration
  4. Use up down arrows to get to Touch Spd Dial
  5. Use up down arrows to get to the desired Contact name or number
  6. Use side arrows to move cursor
  7. Use Delete key to remove and re-enter Name and/or number
  8. Once the name/number appears as you want it, Press "SET"
This should change the name/number individually and in your group.
Best of luck.
Greg
Jun 17, 2009 | Canon Office Equipment & Supplies
Will not find street name in same town
put the name of city as the sub and the put in the street then the number but don't forget to press done at the end of each time if this dose'nt work take it back maureen
Jan 02, 2009 | Tomtom GO GPS Receiver
We have a problem putting in names and addresses.
All tomtoms are more or less the same. You tap the screen to make selections.
Switch on , let it boot up / Tap the screen / Then tap " Navigate to" / then tap "address" / Then tap either "City centre" or " Street and House Number , or Postcode " ( you select one of these by tapping screen ) . Lets say you just tapped "Postcode" . A keypad will appear on the screen for you to enter a postcode. NOW, enter the postcode ... as you enter the postcode , streetnames will appear and you can either continue to enter the postcode OR you can choose one of the street names that appear. Once you have done this , the tomtom will ask you to select a "house number" . if you don't know the number then just 'try' selecting number 1 . Once you have done this , select "Done" and the tomtom will switch for that screen to the "route calculation screen" . if you now tap the screen once more your tomtom will start giving you direction both visual and audible , to your destination . ( you must begin to move before it will start ) . ....................... Once you have completed the journey , you can now cancel the navigation by once again tapping the screen , then use the "right arrow icon" to move through the menue screens. When you see an icon with a RED CROSS through it , and underneath it says " clear route" , select that by tapping and the route / navigation will be cleared. ... Good luck , hope this helps.
Nov 27, 2008 | Tomtom One XL GPS Receiver
How do you DELETE an address, street and city when you no longer need it?
How can I delete a Favorite?
1. Tap the screen to bring up the main menu.
2. Tap Change preferences to open the Preferences menu.
3. Tap Manage Favorites.
Tip: Tap the arrow to move to the next page buttons.
4. Tap the Favorite you want to delete.
5. Tap Delete.
May 04, 2008 | Tomtom ONE GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
52 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
