I turned my Canon LaserClass 7500 off to replacer toner cartridge. When I turned it back on, it appeared to go throught the startup stage, but all I get are horizontal black squares on the status window. Tried restarting. Unplugged and replugged power supply. Opened and shut all doors. Pressed all buttons. No luck with any attempt. Working great before I shut it down.
  • Marfixa Apr 12, 2008
    I'm back and running. It worked. Thanks
  • 47 Answers
Try reseating the toner cartridge
hope this helps
Posted on Apr 10, 2008
Hi mi sumsingcxs6345nis tuner error
See the section on Replacing the toner cartridge in page 10.3 of the manual.
When the toner cartridge is completely empty:
• Toner Empty, Replace Toner1 appears on the display.
• The machine stops printing. Incoming faxes are saved in memory.
At this stage, the toner cartridge needs to be replaced.Check the type of the toner cartridge for your machine. (Page 12.1)
There are many well explained steps in the manual.
http://downloadcenter.samsung.com/content/UM/200810/20081010120126000_Guide_EN.pdf
Mar 07, 2016 | Office Equipment & Supplies
Check cover/cart appears. tried changing toner cartridge but message still there. Toner in correctly. is there anything else to check/do?
the message you are getting will show up for both toner and cover. There is a switch that the cover triggers when closed located onder the main unit cover. The tab on the cover goes into a slot located kinda left of center. That switch is infamous for getting stuck or knocked out of place so the tab does not see it. The cartridge is probably good.
Sep 19, 2011 | Canon LaserClass 2050 Plain Paper Fax
The pages are coming out blank in the middle
Remove the toner cartridge and shake it side to side a few times then re-install. This is the most common solution and also may mean your toner cartridge is getting low on toner. The other possible cause is dirty laser optics but that tends to come on very slowly and over time. If this appeared fairly sudden then it is the toner.
Good Luck and Thank You for using Fixya
May 06, 2010 | Canon LaserClass 9000L Plain Paper Fax
How do you clear documents received in memory?
sir, its simple if you want to clear all the docs received. but its difficult if u just want one doc to vanish. To clear everything just remove power cord and communication media for 5 minutes. Hope this solves you problem.
Jun 22, 2009 | Canon LaserCLASS 7500 Plain Paper Fax
I am trying to find out how to replace the Rollers and Drum on a Canon Laserclass 9000l? I can't find the part and canon help requires me to have the serial number of my machine at work and I am at home...
The drum is inside the toner cartridge. That is not replaced separately. Which rollers are you trying to repalce? There are several. Have you tried cleaning them first with a rag and some rubbing alcohol?
Jun 19, 2009 | Canon LaserClass 9000L Plain Paper Fax
Red light blinking and printer error "check printer ##330" appear
## 330 Power Supply (Replace/Repair)
Replacement part number is HH3-5278
Apr 22, 2009 | Canon LaserClass 7000 Plain Paper Fax
Can i use any ink film?
The Canon LC2060 uses a powdered toner in replaceable cartridges. It does not use ink film.
Mar 05, 2009 | Canon LaserClass 2060P Plain Paper Fax
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
Dec 03, 2008 | Canon LaserCLASS 7500 Plain Paper Fax
Black Copies
is there toner in the machine ? ( toner spill)
check the manual for the location of the glass, in the maintenance section, if it has toner on it copies will be black or dark, other wise the scaning glass is bad
http://www.retrevo.com/s/canon+7000+manual
Dec 31, 2007 | Canon LaserClass 7000 Plain Paper Fax
83 people viewed this question
jasbo
jasbo
