Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Drill head How do you remove the drill head?? i'm trying everything but i just don't know how to take the existing drill head put to change it to another one
    Champion:
  • 313 Answers
Are you saying the chuck .be specific
Posted on May 29, 2008
How to remove bit from the 5351
the parts are obsolete to replace in the most case if it will come out the driving guidance is often worn in the bit holder and a
lockup will repeat soon
Sep 09, 2012 | Milwaukee Drills
How to remove a keyless chuck from bdf452
If the head of the screw is stripped out to much for a driver to grip and remove it you have two options.
1. Use another drill to drill in the center of the screw with a bit just big enough to remove the head. With the head of the screw off, the chuck can be removed from the spindle. There should be enough of the screw remainin in the spindle that you can grip it with vice grips and remove it.
2. Using a metal cutting wheel on a grinder, you have to cut the end of the chuck off, aiming to cut just under the head of the set screw so you don't damage the spindle. After cutting, let things cool off before trying to remove the rest of the chuck and screw from the spindle.
Aug 11, 2012 | Makita BDF452HW Factory Reconditioned 18V...
How to change cells in cordless batteries
It's very difficult to replace the cells and get everything soldered correctly. The best solution if you don't want to buy new batteries, is to take them to a place like batteries plus or a similar place and have them change the cells out.
Apr 24, 2012 | Bosch 13624 24V Cordless Hammer Drills
Don't know how to attach a screw on to my corded Skil 3/s drill. Is there a special bit for this purpose?
Hi auntygamma,
Welcome to fixya!
Yes, you need to use a bit with all drills. They come in different sizes and shapes. If you don't have any bits to put into your drill, an all purpose kit would be nice to have. You can find them at your local hardware store or online.
Check out this webpage: http://www.toolup.com/dewalt_dw2163_37-piece-screwdriving-set-with-tough-case.aspx
Copy and paste this entire web address into your browser and a page with one of the kits on it will open up for you. You don't have to buy a kit with lots of bits, you can pick up just one or two bits that you would use the most at the hardware store. The most used bits would be the #1 and #2 Phillips bits and a couple of different sizes of flat bladed bits. A few drill bits might come in handy too.
The drill that you have has a keyless chuck. This means you don't need any special tools to put in a bit or change one. If you look at the chuck, you'll see that the ridged part has two sections. If you hold the back section with your left hand, you can turn the front section to either open the chuck or close it to put bits in.
I don't know if this was clear or not, but if you have any problems or more questions about this, please be sure to reply back. I'll be glad to help you.
Thanks,
Handie Andie
Aug 14, 2011 | Craftsman 3/8" Corded Drill
How do you change the 1998 audi a4 quattro cylinder head bolt. One of mine broke.
They make extractors that you could try and use to remove it you have to drill a little hole and then insert the removal tool, but they make different kinds. Worse case would be have to remove the head and hope that there is enough bolt left to get vise grips or something else clamped on tight enough to remove the bolt. Or the bolt will have to be drilled out and the hole re-tapped. This last step should not be attempted by a novice, but can be done successfully.
May 21, 2011 | 1997 Audi A4
I have a 1985 Chevy pickup and I want to put a newer model bench seat, how new can I look at, ie 1995, 2000, 2005????
You can likely put any one you want in there, if you don't mind drilling holes in the floor. As for the brackets actually lining up... don't know. Your best bet is to take a measurement and head for an auto wrecker to see what you can use.
May 11, 2011 | Chevrolet 1500 Cars & Trucks
Driver does not retract
Most likely it is broke. You won't know till you take the head off. Be careful of the seals and springs when you do it. Lube everything back up with oil before putting it back together.
Feb 03, 2011 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Remove existing phillips no chuck avalible in this model
Take a phillips screw driver and stick it into one of the key holes. Then take a flat head screwdriver and stick in one of the slots. And prise against the phillips.
Or you can wrap a belt or strap around the chuck hold it tight, then put the drill in reverse and unscrew it.
May 30, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Need to change a keyless chuck
open jaws for large size bit.look in bottom and there will be a screw slot or phillips head screw or possibly an allen head screw.remove this,by possibly turning clockwise. and then chuck up a large allen wrench. try removing the chuck by tapping wrench with hammer. this may be threaded on counterclockwise.have to try both ways.
Aug 28, 2009 | Craftsman 19.2v 3/8"drill/driver W/ Work...
How to change a nozzel
to change the chuck you must remove the screw inside chuck by turning clockwise as it is cross threaded then place an allen key in chuck tighten and hit several times with hammer till chuck lossens
Feb 23, 2008 | Dewalt 18 Volt Compact Drill Kit
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
141 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
