Panasonic older big screen tv
I was trying to turn off closed caption, and now all I have is snow.
  • Pam K Apr 10, 2008
    I was trying to turn off closed caption and somehow lost the picture, now all I have is snow.
  • 54 Answers
Pls. check your cable box, if you have a cable box and it contain input- output audio video select video to your tv set maybe you scan from video 1-3. then check your RCA jack
Posted on Apr 11, 2008
A black rectangle has appeared on the screen, blocking out most of the picture. How do I fix it? thanks
Ur tv still have the funsctions ON like Close Captioning.U have the tv original remote wright?Yes?Tries the remote button like CC on ur tv remote pushes it a couples make sure like CC1,2.3..turn all off.Tries go into the tv Menu tries looking for Closed Captioning functions turn CC1,2,3...turn it all off and Text1,2,3...turn it all off too.These two functions off.Tv will stop this big black box poping up on the tv screen.
Sep 06, 2011 | TruTech PVS31170S1W 17 in. LCD Television
My 9" Broksonic TV/DVD player
Will tries go into the tv screen menu again tries see if u can locate and functions like TEXT ON/OFF TEXT 1,2,3..Tries to off all that.The Close Captioning 1,2,3.. and TEXT 1,2,3..are same functions as TEXT 123 3..funsctions have a permanation of a big black box on the tv screen as Close Captioning functions writting without the big black box on the tv screen.
Aug 18, 2011 | Broksonic TV
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Televison & Video
Tv has a solid black box in the middle of the screen, how do i get rid of it?
Try turning off the closed captioning. I had an older panasonic that did the same thing-still don't know how it got turned on in the first place.
Dec 22, 2009 | JVC Televison & Video
Big black block in the middle of tv
Check youron screen menu setting for Closed Caption (CC) and turn it off.
Oct 29, 2009 | Philips Magnavox 27MS343S 27" TV
Black block fills screen
Turn off the closed-captioning. It's set for "text" and the TV is blanking out the screen where the text would go if there was any. There's probably a single button on your remote to control captions, and it got pressed and put the set into text mode. Just press that button until the TV says "off" or use the TV's on-screen menu.
Apr 23, 2009 | Televison & Video
Black square in center of screen - no "closed caption" solution
Here are the steps from the owner's manual:
1. Display MAIN MENU. Press ACTION key on remote.
2. Display SET UP TV screen. Use arrow keys to select TV icon and press SET key.
3. Display CAPTION screen. Use arrow keys to select CAPTION and press SET.
4. Select CAPTION MODE. Use arrow keys to select CAPTION MODE. Press SET to cycle through caption settings until it says OFF.
5. Press ACTION key three times to return to normal screen.
You can download the manual from Panasonic here if you need a copy.
Apr 03, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
How do I get to closed captioning on the TV?
You will need the original remote. The TV/CAP/TEXT button turns it on and off. The CH.1/2 button switches between channel 1 and 2 of the closed captioning.
Dec 08, 2008 | Orion STV2763 27" TV
Big Black box covers screen
On the remote control is a button called closed caption or CC.. Someone turned on the closed caption. Simply turn off the closed caption. That black box is called the text box. Good Luck
Apr 12, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
