Question about HP DeskJet F380 All-In-One Printer
Refillable ink cartridges
I just want to know if a hp 21 black ink cartridge can be refilled?
    Scholar:
  • 58 Answers
Yes it can
Posted on Apr 10, 2008
I have a HP 1460 printer & I have now no black ink in my printer.can this printer support any duplicate cartaige(local cartaige)?
No, that printer only uses the 21 Black and 22 color cartridges. The best thing to do when you run out of ink is to buy a refill kit and then refill each cartridge at home. This saves lots of money in the long run. Click on the link below to view a refill kit for your HP D1460:
http://cgi.ebay.com/Refill-ink-HP-21-Deskjet-1420-1430-1460-BK-4oz-s-/320621581336?pt=BI_Toner&hash=item4aa6891418
Feb 13, 2011 | HP DeskJet D1460 InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
May 28, 2010 | HP Deskjet D4260 Printer
How i can refill 818 ink jet
here you can find instruction on video
for the black http://inkfilling.net/instructions-on-how-to-refill-hp-21-c9351a.html and for your colol cartridge
http://inkfilling.net/instructions-on-how-to-refill-hp-22-c9352ae.html
May 20, 2010 | HP DeskJet F380 All-In-One Printer
Hello,after refilling ink cartridges HP21 and
Since HP’s ink technology is different from other manufacturers, they do not recommend to use refilled or remanufactured ink cartridges. Though the cost of genuine HP cartridges are bit expensive than the other cartridges, HP cartridges are manufactured in keeping mind the important factors print quality and customer satisfaction. Using the refilled cartridges may degrade the print quality and may damage the printer’s internal hardware.
I request you to use genuine HP Inkjet cartridges and verify the result.
:) Dr Tony
May 10, 2010 | Office Equipment & Supplies
I want to refill my HP J3680 printer black cartridge
That's easy. Take out the cartridges. Your black cartridge is number 21 i guess, so all you need to do is take off the label on your cartridge. You will see a single hole. You need a syringe and needle to do the refill. Put 10ml of black ink in the syringe, put the needle in the hole. You will feel a slight resistance- that is normal, there is a sponge inside, nothing you can damage. Pour the ink. Usually, cartridges are not entirely empty, so if ink begins to emerge from the hole, or starts leaking from the print head, just extract a ml or two, wipe the cartridge with some tissue and voila!
Now don't be surprised if the printer keeps telling you the cartridge is empty, that is normal- neither the printer or your computer can know that you have refilled your cartridge. The ink level will appear only when you put in a new cartridge. You can try and find in printing preferences how to shut down the warning, or you can just ignore it ;)
Hope that helps!
Mar 04, 2010 | HP J3680 Officejet All In One Printer
Printing problems
If you don't use the printer often it is possible that the ink gets dried inside the cartridge, hence you get the print out with low quality or blurred. We suggest you to use original HP cartridges and keep using the cartridges frequently.
Thank you for using Fixya.
Dec 12, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
HP DeskJet F380 All-In-One Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
