Question about Kenmore 22422 Top Load Washer
Coupler we have machine apart and it has the same problems others have won't spin out so where is the coupler??? WHat does it look like? The thing I tried to move only went part of the way didn't make a complete circle.. Please Help!! Thankyou
  • 290 Answers
Remove the clips holding the waterpump and move it out of the way. Unplug the motor wires and remove the clips holding the motor and remove the motor. The coupler is between the motor and gearcase. It consists of two plastic pieces and a rubber piece between them. One plastic piece on the motor shaft, one on the gearcase shaft, and the rubber sandwiched between them.
You can go to sears.com, click on parts, enter your complete model number from the washer, and veiw a parts diagram of the machine. This can be helpful in disassembly and reassembly.
Mike
Posted on Apr 12, 2008
My Kenmore washer (22712) won't spin. It washes and drains.
The number one thing wrong when that type top load washer makes noise and does not spin, is a broken coulper between the motor and the gearcase. This tip i wrote will show how to replace the coupler...follow it to take apart the washer to see if the coupler is broken,if it is my tip will also be helpful to replace the coupler. http://www1.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Oct 08, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
Washer does not spin drum when on the spin part of the cycle. The motor is running and it sounds like the pump is running but the drum is not spinning.
The most probable thing wrong prohibiting it from spinning is going to a broken motor coupler. This video i have included will show you how to take the washer apart and replace the coupler..follow the instruction of how to get to the coupler and see if any of the 3 parts of the coupler is indeed broken.
If it does turn out to be the coupler. The part number for it is 285753A it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
here is the linkto that video... http://www.youtube.com/watch?v=9K1KHEogf3c
GENE
Aug 29, 2011 | Whirlpool LSR5132PQ Top Load Washer
My Kenmore washing machine, model number 26812690, won't agitate or spin. It goes through all the cycles but the tub doesn't move
if its a direct drive , make sure the brake is releasing for starters, If the spin basket has difficulty getting up to speed, you have a slipping clutch. You can determine this by slightly holding the spin basket when you select spin.A rapid spin up to speed shows a "good" clutch. other things to check for are a broken coupler, or any item trapped between the drum and housing, ( which is what happens most the time, )
Jul 09, 2011 | Kenmore Washing Machines
Maytag navigator washer not draining all the water out
Hello there and thank you for choosing fixya
Here are some things for you to check out
Please read fully this covers a couple of different brands but it is all the same things to check ok?
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jun 23, 2011 | Maytag Washing Machines
The spinning thing won't spin all of a sudden. The washer is making a lot of noise and will drain but won't spin. How do you take the back off?
The motor has a double pole on it. The pump is driven on one side of the motor. The basket is driven on the other end of the motor. So if the water is pumped out then the lid switch is fine. What you have is a broken drive coupler. Usually breaks on a heavy load like rugs or quilts. Low water on a heavy load can break it too. Or simply old age.
Video:
Repair manual and more photos HERE
May 07, 2011 | Whirlpool LSN2000LW Washer
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
I have a Kenmore 110 20692 000 washing machine. Last week it stopped working, and wouldn't spin. It would go to that part of the cycle, but made a kind of grinding noise. I asked on fixya what the...
Normally that motor turns one direction for wash, and another direction for spin. Suggest you undo the coupling again and run the motor firstly in a wash mode. If all is well, forward dial to spin mode then watch if motor changes direction. If it doesnt, very possibly the timer is faulty. If it does change to the spin direction then your gearbox has a problem. Once the reverse direction comes into play, it is supposed to activate a series of gears in the gearbox which will engage the large drum into a spin direction. If there is a loud grinding noise then possibly a gearbox issue. email address is terfou@imaginet.co.za
Aug 30, 2010 | Washing Machines
Maytag performa. wtaer will not drain.machine will not wash or spin
The motor ia attached to the transmission. This is called a direct drive system. Between the motor and the transmission is a coupler. The coupler has sheared apart causing your problem. The coupler is very inexpensive although it will take a little muscle to replace
May 14, 2010 | Washing Machines
Kenmore 22422 Top Load Washer Logo
18 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
