Question about Hitachi 53UWX10B 53" Rear Projection Television
Send me info on how to fix convergence myself
Your lifesaver...dr
  • 1 more comment
  • donru Apr 10, 2008
    I'm in love ...with is site and their support...thanks guys !! dr
    How does the fixya warranty service work ? Can I call and ask a question before I purchase ? Are there repair places in my area?dr
  • TR1234 Sep 30, 2008
    I have a Hitachi 53FDX20B. I saw on another site on accessing the "service mode" to adjust convergence manually. After following instructions and writting to ROM I received an "Overload" error. Does anyone know why this could happen. I also followed the instructions on how to access the front panel to locate the little blue button to take it out of "Static Mode" and return to service mode. Tried adjusting again but same overload error. Thanks for any advise you may have.
    Here is the procedure I followed:
    Manual Convergence for the Hitachi
    1) Receive an NTSC signal.
    2) Press Magic Focus to begin magic focus
    3) Press magic focus again during the magic focus process to get the ?stop? screen
    4) While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and
    the service grid (64 point grid)
    5) When you first get in here? I believe red is the selected color by default (it is flashing).
    6) To choose other colors to converge, use the following buttons on the R/C:
    a) ?STATUS? - Green
    b) ?0? - Red
    c) ?ANT? - Blue
    7) Start from the center of the screen and work your way out on one color at a time. I adjusted red across the
    whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
    may want to go back and adjust some red again? etc. until the convergence looks good.
    (a) Use 4, 6, 2, and 5 on the R/C to move the cursor position(dotted lines).
    (b) Use thumb stick to move the convergence point color.
    ** There have been other posts in here to tape together the color filters found in the Avia DVD to help converge
    lines more easily. I have used this method, and it works well for adjusting to a greater detail. Basically, you put the
    red filter next to the green and adjust your red to the green line both horizontally, and then vertically. Then you do
    the same with the blue next to the green. Some people recommended you should be at normal viewing distance. I
    did mine from just a few feet back from the set. Maybe my eyes aren?t as good? maybe I just felt like it worked
    better this way. There are some other posts also recommending using binoculars. I think it?s great that people
    suggest things to make the process easier? but my girlfriend would think I was insane if she saw me with
    binoculars on the couch adjusting the convergence. I don?t know? whatever works best I guess.
    8) I did not adjust the green at all. I use the green as the guide and did not adjust the location of any green point.
    This is highly suggested unless you have geometry problems.
    9) When going along the lines and adjusting, you may run into the problem of getting an ?S? curve on the line.
    You?ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the
    line between the points will not straighten out (it bends between the points). To fix this, the manual recommends
    going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is
    also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in
    (13x9) mode (64 point). If you have serious problems, the grids work as:
    3x3 - ?coarse?
    7x5 - ?medium?
    13x9 - ?fine?
    10) To get to each of these patterns use the following on the R/C: (only if you need to)
    1. (3x3) Press ?STATUS? 5 times (only works when DCU is in uncorrected state)
    2. (7x5) Press ?0? 5 times
    3. (13x9) Press ?ANT? 5 times
    11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point? depending on where
    you start, work your way up, and always finish on the 13x9
    12) When finishing up the 13x9 mode, to get additional ?grids? on the edges of the screen, press the PIP CH button
    on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence
    as necessary. To exit, press PIP CH again.
    13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed
    to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write
    displayed data to ROM.
    14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
    15) Green dots will be displayed when operation is completed.
    16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
    17) Press PIP MODE and then PIP CH to initialize Magic Focus. The initialize operation starts and several
    windows appear during this operation. It takes about 30 seconds or less.
    18) When green dots appear, initialize operation is finished.
    19) Turn power OFF.
    21) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just
    to make sure the magic focus still works (and that you did the last few steps properly)
  • Hitachi Master
  • 8,617 Answers
Go to this link they have your ics and they send the instructions with the ICs and will send an email that will sign you up for free tech support by on line chat with a tech which is free. Your model uses two Convergence ICs they Are both STK392-110 heres the link.
Posted on Apr 10, 2008
  • Sonny Berry
    Sonny Berry Apr 10, 2008
    youre welcome. I enjoy helping people with their projection issues. Been doing it for about 27 years and truly enjoy helping someone save money doing repairs that can be handled without calling in someone that will charge a high price for 30 minutes work.
  • Sonny Berry
    I am not sure fixya does any service. the link I gave has nothing to do with fixya, that is another site all together I just happen to be one of the other sites support and repair techs. I rebuild boards for them.
Im missing the screws on the arch bit of the studio headfones by dr dre ... wer can i get them damn screws... and cn i put the screws on myself???
phone moser support OR email them thell most probs send a brand new one
OR if yu bouht from a autorised seller then take it to them they should replace it
Jan 24, 2011 | Monster Cable Products Monster Beats By Dr...
Internal battery has come loose and requires refitting and or replacement. There are no service agents in my area and I'll have to do the job myself. Are there any instructions/manuals available for this...
If it is a drum machine, why have you posted this query under Cameras ? You may get more help posting it under musical (and I use the term loosely) instruments.
Nov 13, 2017 | Roland DR-3 - DR. RHYTHM Drum Machine DR3
JVC av56wp74 red lines won't converge. How can I fix it myself. I have seen that a few people have done it themselves, wondering if I can get some info on how much parts cost and if It is the chip is the...
1. disassemble front speaker panel.
2. locate circuit board in front with the 2 large black or silver heat sinks standing up. (this is your convergence board).
3. disconnect all the wires on this small board, but make sure you take a picture first to know where they all go.
4. look for 2 black cips that says stk ***-***.
5. order replacement chips on line.
6. learn to solder before chips get to you home.
7. watch you tube videos titled "how to fix tv convergence.
8. wa, la send me some money to show me your appreciation, lol.
Jun 04, 2009 | JVC AV-56WP74 56" Rear Projection...
A portion of the left side of my TV looks 3D.
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 there is 3 of them in a roll on right side of FBT/flyback ttransfomer they are small brown rectrangler lookins caps but are FUSES it will be the one in the middle.
Feb 04, 2009 | RCA HD52W59 HDTV Projection Television
Blue convergence wont move to the center with the yellow plus sign my picture is yellow and blue can I fix this myself
no you will need to send it to a shop to have it will be something to do with the convergence controls .you have 3 tubes red green and blue there is no yellow tube...have a shop fix it
Dec 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
If you can solder its an easy fix. replace the convergence ICs. If you need further info let me know.
Dec 28, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Convergence off
Convergence amp ic bad
Or send to
good luck
please mark the post with a fixya
Mar 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Need info onhow to fix
Fix convergence issue first = bowing / distortion will go away.
Requires changing large STK IC's and possibily a pico fuse
in the power supply......................T.
Oct 23, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Convergence Problem?
Mike, on this set don't bother with the chip changing as the complete convergence amp. board is only 63 bucks. Check it out here: Good luck
Apr 26, 2007 | Samsung PCL545R 54" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
207 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
