Panasonic WIDESCREEN 52" hdtv: power tries to come on and then there is a burning smell. The power button LED on the TV flashes several times. This starting happening after the TV was on and suddenly the screen turned bright and shut off.
    Scholar:
  • 170 Answers
Check of fluid leak from the tubes, check to see where the burning smell is comming from. could be anode, hv wire, splitter, surge caps in h-circuit, but it sounds like a high voltage transformer.
what is your model number of your tv?
Posted on Apr 10, 2008
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
Mitsubishi lt 52149 52 hdtv will not come on. Like no power. Smell burnt smell at top. Is this something I can possibly repair myself if handy?
No,tv do not any indication of any LED lights that light up at all or any blinking LED lights at all wright?Yes?This tv have major components parts on in one board or could be any boards parts are completely fries and could spread all over the tv other boards too.That why u able to smell burn smell,minor problems don't have a deep smells like that.Best get a quotes from tv Techs from many tvs shops best prices u decide and get it fixed by a tv tech certified professinal.
Aug 22, 2011 | Mitsubishi LT-52149 52 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
Rca dlp hdtv widescreen - terrrible noise/flashing light
if its a dlp its most likely the color wheel that is causing the problem. Post your model number and i will assist you.Please respond to this same post.
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
The blinking status & Time LED lights
DM board n/l/a ....
the only and best way to fix this TV ! ! !
you need to replaced the chassis !!!!!!!!!!!!!!!!!
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Jan 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA 52" HD Widescreen
Only thing can suggest is try the bulb itself to see if it got damaged in transit.
May 22, 2007 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
