Question about HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 Fax
My fax sometimes says out of range and will not accept sending the fax
  • 3 more comments
  • Anonymous Apr 22, 2008
    how do I send a fax with my HP 3050 all in 1
  • Anonymous Jun 19, 2008
    out of range when faxing
  • teeshot Sep 25, 2008
    All of a sudden my HP Laserjet 3050 will not send faxes. I've called my phone from the fax so I know that works. I tried faxing to my husband's fax and it rings, but just won't fax. I've unplugged and rebooted. Nothing seems to work. Now what??
  • klkuhns Oct 10, 2008
    My machine did the exact same thing. I thought it was my digital line but then remembered it did work after the change. I don't use it often so it has been a long time since I have sent a fax.
  • Lmorgan1129 Oct 10, 2008
    i need to clear the memory i cannot fax
I can't send ma fax at a tym so ma box abused me it hurts
Posted on Nov 03, 2008
Cannot send a fax using an hp 3050.please help me get a hint
Posted on May 06, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
For Teeshot: Make sure your line is plugged in the correct spot (line icon, not phone icon). I had the same issue and this magically solved it. the cable got unplugged for some valid reason and plugged back wrong
Posted on Oct 20, 2008
I can send a fax on my HP 3050 but I cannot receive a fax
Look in fax menu, to see what is the FAX RECEIVING MODE. It must be set to FAX.
pifonski
Mar 02, 2011 | HP LaserJet 3050 All-In-One Printer
Hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Dec 13, 2009 | HP LaserJet 3050 All-In-One Printer
HOW DO I GET A FAX SEND CONFIRMATION HP MODEL 3050
entre nas configuraçoes de fax e selecione a opçao para imprimir relatorio de envio
May 15, 2009 | HP LaserJet 3050 All-In-One Printer
SENDING A FAX TO MULTIPLE RECIPIENTS AT ONE TIME
Type in the first fax number, then hit the Enter key (the check mark), then type in the next number, hit the Enter key, and so on until you've gotten all of your numbers entered. Then hit Start Fax.
Feb 25, 2009 | HP LaserJet 3050 All-In-One Printer
Fax procedure in laserjet 3050 model
Press the Menu button and there is option to set-up select that option and there is another option call fax set-up there will be three option.
Fax recieve set-up , Fax send set-up and all faxes set-up from these three options you can set-up fax on your printer.
Thanks and Regards
Nov 26, 2008 | HP LaserJet 3050 All-In-One Printer
MY HP LASERJET 3050 WON'T SEND FAXES
While its possible, I doubt your doing it wrong...
  • Select [FAX], place the paper as indicated on the tray, type the number, and hit send. That's about it.
However, Fax machines will not send when attached to a digital phone network, used over IP phones, or in conjunction with DSL service without the lines being conditioned. This is a small device which hides the higher frequency noise from the fax machine. Any sort of signal shared on the lines may interfere with sending, recieving, or both. If you use DSL for example, I'd almost guarentee this is part of your problem.
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Memory full
How i can delete fax HP LaserJet 3050 memory?
Feb 07, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
1,806 people viewed this question
Seeker5211
Seeker5211
