Mmm, everything but sound. i'm guessin that the sounds is turned on in the menu and turned up to a known good level. so i would take off the back check all connctors to see if they are all pushed in correctly. if you still have no sound. look around for damage.
I would start looking for burnt resistor or audio ic, check voltages.
if you see somethng between a heat sync and an ic that is not firm but melted, then clean it up and try to get another piece from another area of the board buy cutting one in half. also if you don't see any problems. then i would check to see if you need a firmware upgrade. I believe that only service techs like me are allowed to do this. enless the company sends it to you.
the worst case would be that the main board needs replaced.
Please dont forget to vote if you liked my answer
thanks
