Question about Samsung 4 Channel Dvr
Samsung SHR-1040 O/S and Video format/file
Are you able to remove the HHD from the DVR and save the video on a PC for viewing later. I have been able to connect the HHD as an external drive (via USB) to the PC, but I'm unable to access the drive. I assume that the unit formats the drive and then partitions the drive placing some type of O/S on the smaller partition and MPEG-4 video on the larger partition. Drive shows up in the disk drive of device Mgr and also in the Computer Management area (Disk Management). Both partitions show as Healthy, but as Unknown Partitions. However, it does not show up in my computer as a drive. Bottom line, I would like to swap drives keeping the unit operational and be able to view the video on the removed drive on a PC.
Txs. ahead,
Turk
  • 80 Answers
The only way to do this is to directly back up the video to your pc from the unit. mj
Posted on Sep 07, 2009
If a file is a *.bu is it possible to view this file. Or is it possible to convert it to *.avi?
Before we convert BU to AVI, we need to figure out what is BU file format. BU files are uncommon files primarily associated with a Samsung DVR like CCTV (Closed-circuit television) recording system. Bu files contain surveillance video in a proprietary Samsung format and are playable on Samsung devices or with Samsung's video software. When you are trying to open a .BU file on Windows, Mac, media players, iOS, other portable devices, you will get the info that BU files are not supported by them.
To convert BU to AVI, we need a converting tool. Find Cicever BU Converter to have a try. It also provides a nice guide on how to convert BU to AVI here: http://www.cicever.com/how-to/bu-converter-player.html
Nov 01, 2010 | Samsung SHR-5162-250 16-CHANNEL DIGITAL...
I changed the passwors of samsung shr-1040
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Apr 08, 2009 | Samsung 4 Channel Dvr
Samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
Apr 05, 2009 | Samsung Home Security
SAMSUNG DVR SHR 1040
I believe there is a small hole on the face of the unit. power down the unit and incert a straighten paper clip to push the reset button, power up the unit wait 30 seconds and it should reset. if that does not work get back to me.
mj
Apr 05, 2009 | Samsung 4 Channel Dvr
I have a samsung home security shr-1040 and i tried to change my password and i must have put a different 4 digit code than i meant, i am now locked out and cannot access my settings.....please help
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
Dec 25, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Aug 27, 2008 | Samsung 4 Channel Dvr
SHR-1040 Samsung DVR
It does the same thing to me....Can you imagine sitting there viewing the whole hard drive just to see what happen 39 minutes ago. This Samsung DVR is stink.....believe me ...Every problem I read on here,,Im have the same..
Feb 02, 2008 | Samsung 4 Channel Dvr
Samsung shr-1040
Best to get a USB thumb drive and download the video needed to the thumb or flash drive. Put it on the computer and there you can use a program like Snagit to capture the best parts and save it for police. Saves a lot of wasted time
Oct 17, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung 4 Channel Dvr Logo
168 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
