How to turn my tv to AV - Televison & Video
    Scholar:
  • 170 Answers
On the remote do you see a input button?
if no, try channel down below channel 2 and see if you get it.
also you may find this in your menu.
Posted on Apr 10, 2008
Trying to take tv off of av screen without the remote lost it
Turn off the device connected to the av output, then turn TV off and on again!
Aug 05, 2015 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
How to connect ps1 to my tv.?
These are AV connections! When connected with the component phono leads turn on TV, then turn on the PS1 then select AV on the remote to select the AV channel!
Nov 21, 2014 | Televison & Video
32" samsung hdtv flat panel: switches when you don't want it from tv to av/pc or av to tv/pc.
Sometimes, TVs will switch to a new input when they sense a new signal on the new input. So if you're watching TV and someone turns on the AV device (or makes a change that alters or starts a video signal), the TV may switch over to that signal. This is a function of the TV. Some TVs allow you to disable this function, others do not. I looked in the manual and didn't notice where this could be enabled or disabled. If you want to only watch one source, make sure the other sources are turned off.
May 14, 2014 | Samsung LN32A330 32 in. LCD TV
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    How can i turn on the av channel on a sony trinitron KV-25F1U
    Hi, look for a symbol either on the front of the TV or remote that shows a Circle with an arrow pointing into it from the left
    Mar 21, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
    My tv will not turn on and the on timer light is
    Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
    Good Luck...Kim
    http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
    Jan 14, 2010 | JVC AV-36950 TV
    Can i access av channel without remote control?
    If your connecting the likes of a DVD player, Virgin, Sky etc to your Tv via a scart. Then these should turn your tv onto the required Av channel automatically as a scart send power to the Tv.
    Just make sure that you have everything connected up first of all before you turn the power on. Then what I would suggest you do is turn the TV on first then turn the DVD, Cable, Sky on after the tv is already on this should then change to the AV your appliance is connected to.
    Hope This helps you out. Please Leave a thumbs up if this clarify things for you.
    Cheers Little Dish Fitter
    Oct 06, 2009 | Televison & Video
    How do i fix my old tv when i turn it on it just stays black and makes the funny nosie how can i fix these?
    this might not be your old tv doing this have you got the right av cords in Standard AV cord are red, white and yellow then there is HD AV cords that are blue, green ect. make sure you have the right set of AV cord in you tv then at the back of the xbox 360 the part of the av cord that plugs in there is a little switch turn it to Standard or HD this should fix you problem.
    May 07, 2009 | Microsoft Xbox 360 Console
    Can a durabrand dvd home theater system,model #sts96 be used on tv for surround system
    I have a sts92 system and run the tv sound through it for surround sound. My Tv has an AV out option, so I ran component cable from the AV out on the TV to the AV in on the sts92. When watching TV, turn on the theater system and set the function to AV in.
    Feb 24, 2009 | Durabrand STS92 System
    Tune playstation 3 to toshiba television
    first try to manuall select your av channell from your tv's remote control,if this won't work try another scart cable or port on your tv set
    Dec 26, 2007 | Toshiba 55H70 55" Rear Projection...
    Televison & Video Logo
    26 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
