Question about Car Audio & Video
Fiat Bravo radio problems
I recently purchased a 2000 Fiat Bravo 1.2 16v sx, i'v been having trouble with the "intellegant search" radio, scan on / scan off keeps appearing on the screen and it skips songs on my cd player automatically and also when i am listening to the radio it skips stations all by its self, any soloutions to this problem please let me know, cheers
5 Suggested Answers
SOURCE: GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Posted on Aug 07, 2008
r_mcalhoun
  • 166 Answers
SOURCE: my saturn vue radio does not work. CD player works
it probably in the radio it self .some of have 2 fuses check them.better check all fuses. good luck
Posted on May 09, 2009
  • 6 Answers
SOURCE: Recently purchased car has Clarion RDB365 radio/cd player. We figured out how to set the clock, but need to know how to set radio stations. It's a multi-band radio, so the only part that's intuitively
try geting on the station that you want to preset and hold down the buttons at the bottom usually 1-6
Posted on May 19, 2009
  • 186 Answers
SOURCE: car stereo preset radio stations.
Manuallly set to the station you want,then pick a preset button & hold down until you hear a beep or 4 about 5 secs
  • 1596 Answers
SOURCE: 2001 Ford Taurus Radio doesn't work but CD player does!
Possible Antenna Disconected ? Or Plain Radio FAILURE Seen this Before and Radio Muse be Replaced, IF it"s NOT Antenna
Posted on Jun 01, 2009
Heater fuse location on fiat bravo
On this website link below you find fuse box diagram and description for Fiat Bravo
Fiat Bravo 2008 2014 fuse box diagram Auto Genius
Jan 20, 2013 | Fiat Cars & Trucks
Fuse box on fiat bravo 08
On this website (link below) you finde fuse box diagram and description for Fiat Bravo
Dec 25, 2012 | 2008 Fiat Bravo 1.4
I have a Fiat Bravo when i accelerate it jerks off it does that when i accelerate hard
have you tried altering the timing on the engine after you changed the timing belt?
Nov 19, 2012 | 2007 Fiat Bravo 1.4
Where can i find a relay diagram for 09 reg 1.6 diesel fiat bravo, i need to find the radiator fan relay?
We have no diagrams here at Fixya due to the fact this car is not sold in the North American Market
Feb 21, 2012 | 2010 Fiat Bravo 2.0
I have a 98 fiat bravo i think my clutch is faulty
you have to get down the gear box to check it .
maybe it's not a damage clutch .....
Sep 15, 2009 | 2005 Fiat Pininfarina
Problem installing car stereo
THE FIAT BRAVO HAS A STANDARD ISO CONNECTION WHICH SHOULD PLUG INTO MOST AFTERMARKET STEREOS AND THEREFORE YOU WON'T NEED TO KNOW THE COLOUR CODE, IF THERE ISN'T ANY PLUG ON THE STEREO BUY AN ISO PLUG THEY'RE NOT EXPENSIVE AND CONNECT IT TO THE RADIO AND JUST PLUG IT INTO THE CAR HARNESS, YOU DON'T REALLY WANT TO CUT THE CAR'S WIRING
Dec 05, 2007 | Car Audio & Video
Sony cd changer
IF IT'S A FIAT BRAVA ORIGINAL CAR RADIO WITH A SONY CHANGER IT WILL HAVE AN INTERFACE BEHIND THE RADIO WHICH MAY NEED RESETTING IF YOU DISCONNECT THE INTERFACE POWER FOR 2 MINS AND RECONNECT IT FAILING THAT THE SONY 6 DISC WILL BE JAMMED, WHICH IS COMMON
Nov 19, 2007 | USA Spec SCD-A88 6-Disc CD Changer
Car Audio & Video Logo
793 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
