Question about Nokia N70 Cellular Phone
Nokia N70 problems with phone ring
I'm having problems with my Nokia N70. I used to be able to set the ring tone/text message tone to anything I wanted. Now though, it seems to have this preset video tone that no matter what I try, I can't get rid of. I have not downloaded this tone, have no clue where it came from. No matter how many times I try to go in and change the settings I can't get rid of it. Any advice you can give me to get rid of this??
  • 1 more comment
  • o0Kellie0o Apr 17, 2008
    Thanks for both replies! Will try both and see how I go.
  • o0Kellie0o Apr 23, 2008
    Thanks for yr help :-) Managed to fix my phone and it's back to normal now.
  • bijesh_n Jul 31, 2008
    i cant fix my ringtone.it rings the original nokia ringtone even if i have changed it in all profiles.
  • 86 Answers
There is an sms ans ringtone pach on niokia n70 website. Try those
Posted on Apr 12, 2008
Turn off turn usually fixes most problems
Posted on Jul 06, 2008
    President:
  • 1,017 Answers
Find the name of the file/ringtone got to file manager locate it and delete it. Or run an Anti Virus program like McAfee or Symantec.
You may have installed a program on your phone, that automatically installed this tone to load on all profiles.
"Confucius he Say: Woman who cook carrots and peas in same pot not very sanitary."
Posted on Apr 11, 2008
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
When i receive a text message my nokia E72 doesnt ring, what could be the problem?
Does the phone ring when you receive an incoming call? If so, press Menu go to Control Panel (or might be the profile is shown in the menu) after control panel, Profile then Options and then Personalize, then, scroll down and again select Message Alert Tone, set the Tone for the message. Also make sure that the volume is turned up. Save the settings and try again. If this doesn't help and you don't hear any ring tone during an incoming call, let me know after checking the sound settings.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Nokia N72 Cellular Phone
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
N70,RINGTONES
Go on settings.ringtones,move mouse pointing down to get message setting and open gallery with tones some tones are ringing tones some for alert and messages. Just click on one of them and that's it.
If you have a troubleshooting call Nokia providers and ask them they can explain all.
Jun 10, 2008 | Nokia N70 Cellular Phone
Assigning ringtones to a profile
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
Feb 02, 2008 | Nokia N70 Cellular Phone
Message Tone
in profile settings turn off warning tones
Dec 03, 2007 | Nokia 1100
Nokia N70 Cellular Phone Logo
195 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
