I have a home theater system - Cable/TV/Stero/Phillips wireless Remote. Seems like there are a million wires/plug-ins associated with the system. Is there any way to elimiate or convert all the wires?
    Scholar:
  • 170 Answers
It depends on what all you use and how you use your system.
if you have a mess. you can try to zip tie them together.
Posted on Apr 10, 2008
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
How do you connect a Home Theater System to a Sharp 60 Inch LCD Aquios TV for Audio?
Use an RCA cable from the TV's audio out to the AUX in the home theater unit.
Oct 19, 2014 | Audio Players & Recorders
How do i connect my pc to my phillips home theatre system through an hdmi cable
The best way is to connect your laptop to a spare HDMI input on your TV first, then use the AUX OUT from your TV to the AUX IN1 of the Phillips Home theatre system using a standard RCA cable.
The only catch with this is that you will have stereo analog audio, NOT digital surround. However, by pressing the "SURROUND" button of your Phillips HTS remote you can switch the audio output to multi-channel surround, stereo or party mode.
What is the model number of the TV you are using?
Oct 23, 2012 | Philips HTS-3565 Theater System
IWhat's your problem? I have a Hisense LTDN42V68US LCD TV and I am trying to hook it up to a Phillips HDMI DVD Home theater surround system HT53544 my problem is I am not getting a sound I only get so
Good day!!!
Your problem is on your digital cable signal or connection..
Please check all the wirings and connection from the to cable box..
its better if you re insert all connectors and restart all TV,cable box....
Hope it helps...
Dec 06, 2011 | Televison & Video
Hooked up home theater system, sound but no picture
are the red and white for "audio in" to the theater system receiver and the yellow cable hooked up to "video out" on the receiver and "video in" on the tv?
Typically most theater systems do not have "audio out" connections because they produce the audio. The receiver will have several "video out" connections, one of which needs to go to the tv.
Mar 12, 2010 | Audio Players & Recorders
Phillips HTS3566D Home Theater/Comcast DVR 3 Device remote
I have the same problem. The only time that I can get it to work is whenever I turn on the cable box the home theater system turns on too. When I use the DVR it will turn it on too and want to play the CD/DVD. I have a Comcast Motorola DCH3416 DVR box.
Apr 03, 2009 | Philips HTS3544/37 Theater System
I just bought a Dynex DX-LCD19-09 19 inch TV. I also have a Phillips home theater system. I have digital cable and I cant figure out how to hook it up to where i can watch regular tv but hear it through...
The only audio out jack on your TV is for the headphone on the left side of the TV. You need to purchase a 3.5 mm to RCA audio cable, connect the 3.5mm jack to the left side of your TV and the 2 RCA audio cable ends to the audio in of your Home Theater and then select AUX 1 or AUX 2 on the home theater depending on which jacks you plugged into.
Mar 09, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
