Question about Toshiba 50H81 50" Rear Projection Television
Toshiba tos-50h81 convergence issue
Hi guys, i am wondering if any of you can help me out...i have a rear projection toshiba, and the screen appears to have warped into an orb like motion. for instance, watching sports, the scoreboard scrolls on top and bottom bow out towards the middle of the screen.
my question is this: i know there is a way to straighten this out on a convergence screen not available on the standard menu options. this screen forms a graph, and that is where you can correct this problem. can anyone tell me how i can get to this screen??
  • 170 Answers
You have this in your menu. but your menu will not adjust and fix your problem. if all three colors are bowed in at top and green and blue... then you need to change all convergance ic's and check fuses. also there might be some solder in fuses hiding on the board. Need to also check all fuses around conv ic's and around conv yoke plugs.
good luck.
Posted on Apr 10, 2008
Hi I have a toshiba dfs 100 hyper progressive rear projection 67" tv, model 61A9UA and when i turn on the tv rows of what look like are black small rectangular boxes appear. Its still there wether i...
hi i have a Toshiba Dfs 100 & hyper progressive i hve no idea what wrong with my tv.. when i turn the on button the box down the bottom its on nd showing blue color..**** nothing showing on the screen.. pls help me thnx
Aug 09, 2011 | Toshiba Televison & Video
Color on Panasonic 2004 is off and appears to be warped
It sounds like a convergence problem; most of these sets use two convergence IC chips that both need to be replaced; usually this can be done right in your home.
Aug 16, 2009 | Hitachi 53SWX10B 53" Rear Projection...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
Hi, this TV is repairable and you will have to replace two devices. the first is the Convergence board. this device regulates the convergence of the RGB stream so it can be projected evenly. it works in conjunction with the CRT's and deflection assembly and the Focus pack(module). The second device that will need to be replaced is the Focus pack(module). This module is malfunctioning and is causing the smudges and warped look at this time.
Replace these two devices and it will fix this set. i will post the Part numbers below along with there respective prices as well.
Focus Pack(module).--- Part Number-- BP59-00005A--- $38.95
Convergence Board assembly--Part Number---BP94-00383A---- $165.95
Please rate and god bless:)
May 07, 2009 | Samsung HCM4215W 42" Rear Projection...
Blue screen with a floating white orb
if you have the blue screen of death your harddrive is going out. The only way to fix this is have the hard drive replaced. If you have a warranty call the warranty company as they will fix this issue. if not try a local computer repair shop to fix it.
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Just wondering when to replace the blulbs on my Toshiba 57H81 CRT
Hello, Im Ismail A, and I would love to help you with your problem. Ok, well you should change your bulb every 2 years.
Jan 12, 2009 | Toshiba 57H81 57" Rear Projection...
42h81 warped blue
hi, this circuit is not a plug in circuit, is part of the main circuit, I recomend to call for service, some can do it on site (wich I recomend), some will take the chassi (electronic box), or they take the whole tv, wich is not necesary all depend on the company($$),
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba tp5581a 55 in. rear projection tv.....problem
the yokes need adjusting (upside down writting) and the CRTs need alignment
Sep 11, 2008 | Toshiba 50H81 50" Rear Projection...
Warped picture Toshiba 65HDX82
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Jul 12, 2008 | Toshiba 65HDX82 65" Rear Projection...
RCA P52929
go to the menu select the screen option 3 and then select option 6 . adjust projection tv. green is for green use it first then adjust the red and blue until the patterns on the tv screeen appear white.
Sep 26, 2006 | RCA P52929 52" Rear Projection Television
Toshiba 50H81 50" Rear Projection Television Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
