Question about Dell Latitude D600 Notebook
Dell Latitude D600 won't power up
With the external power or the battery I push the power button and nothing happens. Is my laptop dead?
  • 4 more comments
  • Anonymous Apr 11, 2008
    power is not on
  • kasubi peter May 27, 2008
    i trying to push the login button for one minute
    but still doest not log in.
  • Ronalltronic May 28, 2008
    There is an IC burned out. The IC is located under the mountingscrew of the cover from the memorymodules. It's a 8 pens integrated circuit.
    So, there will be no switching power on, with both energy sources.
    I need the number of the ic. Please help
  • SLICKFINGERS Jan 17, 2009
    WILL NOT POWER UP I HAVE A NEW BAT NEW CHARGER
  • Anonymous Feb 15, 2009
    won't power on from power cord
  • sheshe3 Feb 16, 2009
    I have this same problem and when I spoke with tech support at Dell they said it was too expensive to fix; I needed to look at a new laptop purchase. Does anyone know what it should cost to fix this problem with the motherboard? Would you recommend that I just toss it?
Dell power jacks are notorious for losing the solder connections. If all else fails remove the motherboard, use a solder wick and remove the old solder and resolder the connections. There are four pins that are close together so you need to make certain you do not over solder. Hope this helps
Posted on Apr 11, 2008
    Problem Solver:
  • 10 Answers
Hi Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
  • 4 Answers
I have the same problem tha I solved by pressing the power button and the number 7 key the computer should power up.
Posted on Aug 28, 2009
    Guru:
  • 1,342 Answers
Disconnect the power and the battery. Hold the power button in for up to one minute to discharge the laptop.
Try starting it again.
Posted on Apr 10, 2008
Why my lap top battery power goes off soon while starting?
These laptops are notorious for developing battery issues. We've got one at our house that would basically be a paperweight without a charger and external monitior. The best fix for this is to buy a new battery.
May 19, 2014 | Dell Latitude D600 Notebook
I have a dell latitude d600 when i press the power button with the battery in(just the battery) nothing happens. when i plug the adapter in with/without the battery power comes on and the hd light flashes...
Can you hear the fans starting up.....if you can plug your laptop into a external monitor and see if you can see it boot up...it sound as if you may have a short on the battery pack...
Apr 02, 2011 | Dell Latitude D600 Notebook
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Dell Latitude d600 starts up, loads Dell screen, but stops there
try removing the battery . wait 30 minutes. plug the battery back in and try again.
Sep 12, 2009 | Dell Latitude D600 Notebook
Dell D600 battery
Sounds like your battery is bad.Some dead cells i tend to think
Aug 07, 2009 | Dell Latitude D600 Notebook
Dell D600 laptop will not turn on.
hi
I also have 2 D600 and already disassembled them a couple of times :)...I think this might be wrong with your d600 since it doesn't work with the battery either:
under the grey plastic cover with the power on/off buttons and the volume control buttons there is a small electronic board which is attached to the mainboard only by a plug and a socket, so it is removable...a very common problem in the d600 is this connection: either this small power board is simply broken, which is very unlikely unless it suffered heavy external damage :)...or whats more likely, that the solderings of the plug to this board lost their contact OR that the solderings of the socket on the mainboard itself are old from wear and also lost contact and don't conduct anymore :P....I have this problem in 2 d600 but not with the power button but only with the volume buttons :)....
you can try the following to test if this is the cause:
take off the grey hinge cover with the buttons and press a little bit on the right corner of the power board and try, at the same time, to power it on by pushing the fourth of the buttons
if you have trouble taking off the hinge cover or any other questions, or if you find the problem, just send me an email...I'm glad to help...I can also provide you with some helping pics to disassemble the stuff :)
w33rdo@googlemail.com
greetz
Jul 05, 2009 | Dell Latitude D600 Notebook
My dell d600 will not turn on
take out battery out of back and replace
Dec 17, 2008 | Dell Latitude D600 Notebook
Will Not Power Up
the middle one with the A is Caps Lock....
Try removing the Battery from the System.... There is a power indecator on it....... Push the button on the battery Five lights full battery.... No Light Dead.... If Dead Your Power supply might be at fault....
Is the power Supply Light Lit? If No.... Bad Check connections..From Wall to Brick ect.... Still No... PSU Looks Bad....
Jan 07, 2008 | Dell Latitude D600 Notebook
Dead Dell D600
You can get the correct adapter on E-Bay for about $20.00. Just search for adapter D600.
Oct 20, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
1,763 people viewed this question
Alun Cox
