My nad 350 amp was producing a clipping spond and would not work the clipping sound has stopped and the Amp is dead. Is there anything I can do? replace fuse or do I need to send it to a repair shop. joemc@indigo.ie
  • 4,234 Answers
The output section is in need of repair. If you have no experience with this, NAD systems are not hte ones to start with. Look for an authorized NAD servicer.
Dan
Posted on Apr 10, 2008
NAD 7030 just stopped working on one channel. The speaker will work if the mono button is pressed in. Could this be a fuse problem ?
most likely it will be poor soldering on the input side - the fact both speakers work in mono means the pre & main amps are working fine
Feb 27, 2015 | NAD Audio Players & Recorders
Spond keeps popping & cracking & screeching, finally no sound.
Check and replace damaged component/s in the audio output section circuit.
Aug 18, 2012 | Polaroid FLM-323B Television
NAD c272 distrotion
yes........you may have to replace the stk output amp ic or the discrete transistors for the channel affected.....good success, regards, Meder's tv service
Aug 15, 2012 | NAD C272 Amplifier
NAD C272 AMP has little volume and sound is muddy and distorted.
Normaly this is what cause little volum and distortion. Check first if you got +68/-68V on amp module left and right Often the -68V is missing. This is caused by faulty transistor Q712 (2SA872) in +68/-68V power supply.
Feb 27, 2010 | NAD C272 Amplifier
Clip won't restart -dead?
it sounds dead to me
is there a master reset or anything on there?
i dont have oone myself but i have similar things
Feb 18, 2010 | SanDisk Sansa Clip MP3 Player
Losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Sep 17, 2009 | NAD C370 2-Channel Amplifier
Excess clipping on nad 372 amp
อิอิ ขอบคุณคับ
May 24, 2009 | NAD C272 Amplifier
PreAmp to Amp problem
Sorted it. You have to put the plugs back in the PreampOUt/Main in or it cuts out the pre-amp.
Nov 18, 2008 | NAD C320 2-Channel Amplifier
Gem Sound XP-350 both channels failed
Speaker fuses are generally fast-blow styles 250 volt glass
If an amp shuts down, with speakers connected, it sounds like one of the power supply lines does NOT like what it's "seeing" . Probably output transistors bad ( or module)
Take it to a tech.
Scott out.
Dec 02, 2007 | NAD C350 2-Channel Amplifier
113 people viewed this question
 Grubhead
Grubhead
