Question about Vacuums
I have designed a machine for cleaning and harvesting using a centrifugal fan. The flexible hose is 203mm Diameter and 5 metres long. How can I calculate the vacuum pressure this machine creates at the end of the hose? I would like to use this information in the advertising and to compare with other similar machines. Thank you Alan Churchill enquiries@blackskinkvacs.com.au
  • Tank vac Apr 10, 2008
    The information provided does not seem to relate to my machine/problem.My indusrial vacuum machine has a 203mm diam inlet hose with a 13Hp motor driving a centrifugal fan. If I put the hose into a source of water with a dye in it, turn the motor on and see how far the water is sucked up the hose will I be able to calculate the Hg? there are some photos on my website at www.blackskinkvacs.com.au it may give you an idea of the machines involved.
    Thanks
    Alan
  • 818 Answers
I need a Simpson EZI SET dishwasher inlet hose. I have been sent one but it is too short
take the hose along to a hose making shop ( any hydraulic hose manufacturer) and have a hose made to your length
or get your old hose , cut off the ends and use the fittings in a quality hose from your hardware shop
use hose clamps to fix the hoses back on the ends
Oct 20, 2016 | Vacuums
How do I replace sqiggly hoses in my pool - I cannot find these hoses anywhere?
no doubt you need to go to a store that sells pools . I am sure they will have or know where to get it
Oct 12, 2015 | Vacuums
How to Unclog Vacuum Hose
you may have to make something out of heavy spring material so you can push it down the hose and be able to manipulate it.simular to what plumbers use.
Aug 14, 2014 | Hoover Vacuums
The hose is sucking up but the base plate doesnt?
If you have taken the bottom end of the machine apart, you might not have reassembled it correctly so that the path to the floor (base) plate is obstructed when the vacuum cleaner body is laid back, otherwise:
You have either a blockage in the section of the cleaner in the vicinity of the short flexible hose and the floor (base) plate or the the short flexible hose has become detached at one or both ends.
1. Stand the machine upright with the beater bar in the "off " position. Machine switched off but plugged into the mains outlet.
2. Lay machine on its left hand side. You will see the short flexible hose uppermost. Check that it is attached at both tends and has not split or cracked. Check for obvious visible obstruction inside.
3. Remove the floor (base) plate by releasing the three plastic clips with a quarter turn anti-clockwise. Lift floor plate forwards and check no obstruction. Replace floor plate. Stand machine upright on floor.
4. Press two plastic clips to release the inspection cover, on bottom right hand side of machine (when standing behind it). Look into the hole: you will now be looking down into the U-bend that leads to the hose. Switch on the machine: full suction should be at the hole on the side of the machine (otherwise the hose would not have worked). Switch off.
5. Lean the handle and machine body backwards, as though you were going to use the machine on the floor. The hole to the hose now becomes covered and you will be able to see into the short flexible hose that leads to the floor plate. Check for obstruction. Replace inspection cover.
If there's no obstruction and the flexible hose is sound and attached securely then the machine will work - there's nothing else to check.
Jul 10, 2014 | Dyson DC14 Bagless Upright Cyclonic Vacuum
The hose is sucking up but the bottom doesnt...
Why have you posted this question twice on the same day?
Spot bot is blowing not sucking
This problem may be the same as I am having. The SpotBot recirculates the vacuum air back into the brush area when it is using the circular brushes. There is a short flexible hose deep inside the unit that connects from the clear plastic nozzles in the round brush unit to the end of the clear vacuum hose outside. Mine had a large tear in that flexible hose. This causes air to enter the hose and reduces the vacuum action, like cutting a hole in the side of your regular vacuum hose. The bad part is that I have not been able to find a replacement hose. It also takes a bit of repair experience to even get inside to where this hose is. Given the number of references to this type of issue, it appears that Bissell has a design flaw that causes the hose to break prematurely. Any response Bissell?
Jul 06, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
Only suction from hose
What again for the third time? Already answered this but if it helps:
Jul 05, 2014 | Dyson Vacuums
With a new bag -after turning vacuum on, it shuts down
This vac is prone to a control valve failure with the exact symptoms you describe. There is a dial valve on top of the machine designed to regulate how full the bag will get. The valve which sits underneath the dial on the vac likely has a broken plunger and will need to be replaced. Take it to an AERUS Electrolux dealer / shop for an experienced tech to work on.
Sep 13, 2009 | Electrolux Epic 6500 Vacuum
Hiyah i need to know how to get the pipe out so i can clean the stairs
Hi there smartalec from NelsonVacuums.com.au here. Basically there is a colour coded (yellow if your vacuum is the one pictured) big button on the front of the machine where the pole joins the rest of the body just above the yellow part that is on top of the clear bin. Push this in and lift the handle up. Keep sliding the handle up until it make a click sound then press the little button at the end of the flexible hose which will now be at the bottom of the rod. The rod will now come completely off. You can put the cleaning tools in the end of the flexible hose and be cleaning in no time.
Happy vacuuming! :)
Aug 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I can't figure out how to hook up hose attachment to dyson 07
You have a reversible wand on the DC07. You have to separate the wand from the hose first, then turn it around and reconnect it. Once that is done you will be able to use the attachments on the end of the wand. You can also connect your attachments to the hose.
To separate the wand:
1) Take the wand off the back of the machine
2) Place one hand on the Handle and one hand on the gray flexible hose.
3) Push the flexible hose down. You will see a long metal rod appearing. Push until the hose clicks into place at the bottom of the metal rod.
4) You'll see a half-moon shape button with a picture of a lock on the solid gray plastic part at the top of the hose - push it, this will separate the wand from the hose.
5) Turn the wand around
6) Push the purple wand cap with the holes in it back, it exposes a short dark gray pipe, about an inch in length
7) Connect the hose to the short pipe
8) Attach your tools to the top of the metal rod and have fun
Jul 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
275 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
