Question about Dryers
Maytag PYE3300AZW Dryer ran great shut off after 10 min.Willnot start again. Power to dryer is there. Took it apart,brought the door switch in to test it works. There is a live wire on the Timer Wire Harness connected to the motor if you short it out the dryer works normal. Any idea what is wrong? How do I test the thermal fuse? Control Thermostat?Or the Timer.Where to even sart? Any help would be appreciated live 1.5 hrs from a small town do it yourself is usully the easiest way.
  • jamesgang05 Jan 20, 2009
    I started a load to dry and about 10 minutes into the cycle the dryer stopped. It will not start now. We have tested the power sources in and out. Please help!
    Genius:
  • 1,073 Answers
You have an open thermal fuse la1053 located on the right lower side of the heating element housing, it opens when the temp reaches 300 degrees f . this is telling us that the air flow is not good, lint buildup inside the filter housing in the door is a good place to start and or kinked vent hose or venting problem
Posted on Apr 10, 2008
I took my dryer apart and found a staple on cushion of barrel. I did not remover circuit board and may have damaged something. When torn dryer on the timmer light shimmers and will only dry for 30 mi
sounds like u may have a motor winding going bad will usually run 20-30 minutes then shut off and if u run agin right away it will run 10-15 minutes and shut off agin. run an hour later and u will get 30 minutes or so agin? or u may have bad venting causing an over heating prob
Oct 28, 2014 | Maytag MDE2400AYW Neptune Electric Dryer
I have a maytag Neptune NDE3000AYW and the dryer turns on, runs for a few seconds and stops. took it apart and cleaned all the lint and dust. after a while it will run again for a few seconds and stop. ...
Check the door switch. It may be at fault here. Open the door and hold the switch by hand and start the dryer. The switch should have a firm resistance to it when you push it. If you should find this bad, here is the replacement switch. If the switch is ok, then the motor is bad. Here is the motor to order.
Keep me posted!
Nov 05, 2012 | Maytag MDE2600 Electric Dryer
My Maytag Neptune electric Dryer will not stop unless it is unplugged or door is opened.
check the door switch,when you open the door the dryer shouls stop,push in on the door switch and let it out,it should click when it pops out,if the switch broke pushed in it won't shut off.the part number is W10169313 and it's around 16 dollars,
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
General Electric Heavy Duty Dryer willnot start when start button
WARNING: High Voltage may bzzt you... careful.
Your dryer thinks that it is at the end of a dry cycle.
First thing to do is disconect the dryer from the 220v mains and let it sit for about 10 min.
then, spin the timer four or five times around and then stop it at a TIMED dry cycle, not an automatic cycle. (example: 60 minutes).
Plug unit back into the wall.
SLAM door on unit and press button again...
Mar 12, 2009 | Dryers
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Dryer
hI YOU MIGHT JUST HAVE A VENTING PROBLEM iF YOU REPLACED THE THERMAL FUSE & IT WENT AGAIN tHE VENTING SHOULD BE LOOKED AT tHANKS FOR THE QUESTION tHE APPLIANCE DOC
Aug 30, 2008 | Maytag PYE2300AY Electric Dryer
DYRER PROBLEMS
i took the top off checked all the wiring, cleaned the back vents, and the vent tube going outside. I also cleaned the lint screen and gaurd really good, put it all back together. I also unplugged the dryer waited a few minutes and plugged back in. The dryer had a code flashing saying it lost power, I reset the dryer and it has been working great now. Evedently it must be sensitive.
Aug 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
145 people viewed this question
Top Dryers Experts
