Question about Panasonic Workio DP-150PA Copier
Seating the Drum?
I hate to beg for forgiveness in my ingorance, there are two componets that come out of the front one is the toner and then there is the other thing, I assume it is the drum? correct? Does reseating it mean take it out shake it and put it back in?
I thank you for your help and ask for you to clarify. How can you tell if it is a drum issue? We are getting no error lights?
Doug
    President:
  • 2,072 Answers
Yeah, I just mean taking it in and out to be sure you have good connections.
Sorry for the delay, I couldn't find this responce for anything.
My blackberry screwed up and deleted my browser and the e-mail I received.
Posted on Apr 11, 2008
  • Rick Kasper Apr 11, 2008
    Only way to tell if its a drum is by replacement.
    It is either the charge unit in the drum, Or the transfer on in the door. The transfer has to be located directly accross from the drum on the door. It is very close to the drum in order to put a charge on the paper to transfer the image from the drum to the paper.
My printer says drum troubleshooting contact guide manual and maintence I did eveything but still not working
If the display shows drum error you can try cleaning it by following the steps below:
1. Open the front cover. 2. Pull the drum (black) and toner (gray) towards you, put a little force on it. 3. Remove the toner by holding down the tab on the side of the drum, then pull the toner out. 4. Use a dry lint-free cloth to clean the roller inside the drum unit. Make sure to remove any excess toner from it. 5. Put the toner back to the drum, make sure that it clicks, Reinstall the drum and toner back to the machine, 6. Close the cover.
If the display still shows drum error, go ahead and do the drum reset.
1. Open the front cover 2. Press the Options button on the control panel 3. The display should show "Replace Drum - 1. Yes 2. No 4. Press 1 to reset the drum count 5. Close front cover. The display should show the date & time
If still it shows drum error, The drum unit needs to be replace. After replacing the drum unit, do the drum reset again,
Hope this helps.
May 08, 2011 | Brother MFC 7420 All-In-One Laser Printer
It says drum error but the cart and drum is replaced with new and still can't get past the drum error message.
Hi There!
What you can do to clear the Drum Error message is to clean the corona wire.
  • Open front cover of the machine and remove the drum & toner cartridge assembly.
  • Remove the toner from the drum and gently shake the toner cartridge from side to side put it on a piece of paper to avoid scattering the toner.
  • Theres a blue tab on the upper left side of the drum, slide it from left to right, right to left about 5-6 times don't forget to put the blue tab back to it's home position(where the arrow is).
  • Put the toner back into the drum make sure it will click into place.
  • Reinstall the drum and toner assembly back into the machine and close the front cover.
  • LCD should display the date & time.
If you continue to receive the message try resetting the drum counter by doing the following:
  • Open the front cover
  • Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO".
  • Press 1 to reset the drum count.
  • Close the front cover
Hope this helps!
Vikroks
Mar 23, 2011 | Brother IntelliFax-2820 Laser Fax
HOW TO REMOVE TONER CARTRIDGE TO REPLACE WITH NEW ONE
1. Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
2. Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
3. Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
4. Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
5. Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
6. Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
7. Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Feb 09, 2011 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
It tells me to replace the imaging unit i did but it still is telling me to replace the imaging unit any tips on how to resolve this?
sorry about my last reply. you have to replace the selenium DRUM, its a big drum inside the printer under the toner. It cost 150USD... kinda hate Samsung right?
you can also just take it out, shake it left to right several times and put it back and see if you still get the error.
"Pull down the front cover and you have access to the four toner cartridges, which are lined up, one above the other, inside. Unlike many recent colour laser designs, the drum unit is separate from each of these cartridges and has a different lifespan, as does the toner waste bottle, which also needs replacing periodically. "
Samsung has a chip that counts the number of prints you do. After X prints, it wil make you change the toner even if you do not need to. Also you have to replace the selenium drum and also the waste toner bin... I HATE SAMSUMG from now on... CHEATERS
Aug 23, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
My MF8180C is asking to replace the K cartridge, and I have bought a 301 toner cartridge but the printer has a drum cartridge instead. How do I replace the black toner into the drum cartridge or do I have...
the toner crg is located in front of copier, the drum is separated from toner and it removes if you open upper cover.
If the copier ask you for toner open front cover and replace toner.
You do not have to replace drum if the copier doesnt tell you to replace.
Jul 11, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Falal error 173 on oki c5650 after changing fuser unit
Cause:
This error indicates that the Image Drum Up/Down Process is not working properly.
The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Resolution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
http://my.okidata.com/PP-C7200.nsf?opendatabase
Apr 23, 2010 | OKI C5650n LED Laser Printer
Hi there i just replace the toner for my m5200 dell printer and the pages are coming really dark as if the pages are burnt.
Are you using Dell branded cartridges, or compatibles? I've seen issues with compatibles not properly seating when you install the toner cartridge, causing the cleaning blade to not properly wipe the drum (ghosting) or allowing too much toner on the drum (black pages, front and back). Re seating the cartridge should resolve.
Apr 16, 2010 | Dell M5200n Laser Printer
The drum light came on (Brother HL 5240) and I replaced the drum with a new one and it still will not work... Any suggestions?
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Thanks
Jan 20, 2009 | Brother HL-5240 Laser Printer
New toner cartridge and paper jam
Does this happen when you install the old toner? Is the NEW toner an OEM or compatible? I have run into this problem before on some other Brother all in one models. There is a sensor flag located just below the toner and drum unit. Remove the toner/drum unit, check that the sensor flag will move to back and forth freely. My customer removed the toner and drum unit and threw the drum unit away, not realizing that the toner seats into the drum unit. When they placed just the toner into the printer, it read paper jam. Because the drum unit is part of the paper path, the sensor was not in the correct position.
Try re-seating the toner into the drum unit and then re-seat the entire unit into the printer. Let me know if this helps.
Oct 20, 2008 | Brother DCP-7020 All-In-One Laser Printer
Panasonic Workio DP-150PA Copier Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
