posted by photon_3000 on Apr 10, 2008
This is a CRT , not flatscreen TV. After it is on for a while,
suddenly the picture tube seems to go off. It goes black
and there is a tiny bit of light in the center for a split second,
like the power is being turned off. At the same time, the audio
remains, but diminishes slightly in volume. Then, after a few
minutes, the sound come back and the picture returns as well.
This problem repeats and repeats. Now that I am watching
it very carefully, I notice that in the fact the slight drop in
audio volume just barely precedes the blanking of the picture,
just by a fraction of a second. Any ideas? Thaks.
Comment by photon_3000, posted on Apr 11, 2008
Thank you for the answer. Is this something I can fix myself?
How do I determine where exactly the problem is? The TV was recently moved and the problem started right after that. We were really very careful in moving it, but I suspect that that is what caused the problem. Does the fact that the audio volume level drops a little bit just prior the picture disappearing and that the volume level returns to normal just a split second before the picture reappears help to diagnose this in more detail? thanks.
Best Solution
your tv has a loose board problem, its either in main board or CRT socket.
Comment by rickzpert, posted on Apr 16, 2008
I suggest that you refer it to a repairman tech.
Rating Locked! (?) photon_3000 has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Quasar SP-2719 27" TV
Email this problem
Email this problem
Can you Help with these Standard Televisions problems?
Can't get TV picture after...
I hooked up my sony Playstation... Answer This...
Repair Service
Find Standard TV Repairman Near You:
