Question about Casio HR-8TMPlus Calculator
Loading paper tape
I can't even load the paper tape. All I have are little pictures that really don't help.
  • ednacharles Apr 10, 2008
    I have tried all that. So, I gues I won't Accept thus one.
    Sorry, this does not help. Thanks anyway.
  • 3,037 Answers
I had the same problem. I cut the paper at an extreme angle so that I could grab an end of it as it feed through. I then gave it a gentle tug and noticed that it tried to pull something else with the paper. At this point I knew there was a problem and after disassembling it I noticed that the lower rubber roller had burned a flat spot on it and would not roll anymore. TRASH...
Well not really. I ended up getting a bunch of rubber gromits and reinstalling it and it works great. Not really sure it was worth my time fixing it however.
Let me know if you need further help
Posted on Apr 10, 2008
  • Benjamin Patri
    Benjamin Patri Apr 10, 2008
    can you post a picture or two of the area the paper should go in, and maybe we can figure out why none of the above work
  • Benjamin Patri
    Benjamin Patri Apr 19, 2008
    were you able to fix this problem?
  • 818 Answers
Go here for yor support and manual.
Sergio
http://www.casio.com/support/
  • Casio Master
  • 13,433 Answers
Open the calculator, put the paper in, then put the end of the paper into the slot, close it and that should be it..
I have a Luxman KD-117 DAT player that won't accept the tape. Any tape. I load it and the tray closed and a few seconds later opens up. Help please
Hi
I am probably a little bit late but as I own 3 of this model I could probably be of some help.
The main weakness is hardened grease in the loading mechanism, either the tape loading mechanism (the tray that loads the cassette into the deck) or the tape loading mechanism (2 extending arms that load the tape around the heads drum).
An other issue is the switch that detect the presence of the cassette. It is located on the lower right side of the mecha.
Last issue is a rotary switch that gives positioning information to the cpu during the tape loading sequence. Its gear often breaks.
If you are still interested in repairing this unit, one of the finest dat deck ever built, the first thing to do would be to remove the cover and see where the loading sequence stops.
Cheers
Jun 04, 2014 | Televison & Video
Loading paper feed
really need more information. but look for a little door on the back/ bottom and check for a paper jam. do you hear the roller motor trying to pull the paper?
Apr 21, 2014 | Royal Ezvue 550hd Adding Machine
My jvc lcd shutt down every time and i dont know the rason
I can honestly say I have been quite happy with it and its performed pretty well with very few problems and is still going today.
First of all congratulations on getting so many years of heavy use (2002 - 2012) on your JVC VCR.
I have a HR-S3911U and a HR-S5912U from the same era and my 3911 has seen a million miles and both my units are still going strong. I did experience a similar problem with my HR-S3911U but instead of the eject function my problem was with a sticking guide-pin. I did a have similar ejection problem with one of my 1985 Super Beta Hi Fi machines. Really it sounds like the exact problem as you describe. What I did was I opened up the unit and watched carefully - it was just a sticking moving part. My JVC guide-pin problem was just sticking as well - after a gentle push into place the guide pin has not stuck since. I don't suggest using any grease unless you really have to. I suggest you open the unit - if you have a video camera video tape the ejecting and play back in slow mo to see if you can catch the problem. Sounds like a sticking moving part which can be common on any VCR.
..couple times its had issues with dirty heads as i would get a message appear on screen.
I'm very surprised that in the past you had "dirty heads" messages pop up on screen as I have never seen that message on my JVC machines and I do use them a lot and very rarely clean the heads. Proper tape storage is very important. Trying not to use the same tape over and over again also helps keeping the tape path reasonably clean.
I think it could benefit from the heads being cleaned. I don't even really know what are the heads. Is it that big round drum? One thing I did notice is that when I load a tape, it straight away wraps the tape around that drum and the drum spins away and just idles there constantly rubbing on the tape before i have even pressed play. I have left tapes in there for days and days, so I assume this cant be good having that thing spinning away on the tape for such a long time?. I am not sure if this is normal or not but I wont be leaving tapes inserted in the VCR long periods now.
The heads are tiny little things inside the big round drum. I will show you if you post a picture of your unit with the cover off.
The tape staying wrapped around the drum with the drum spinning is normal but the drum should stop spinning five minutes after you load the tape as long as you don't touch play, rec ,ff or rewind. This is called a "long pause" (the tention is a little eased and is not rubbing hard as a normal pause would) and the long pause is there so the unit will immediately start playing or recording if you push play or rec within 5 minutes of loading the tape. If the drum does not stop after 5 minutes of sitting idle then your VCR has a malfunction and you should not leave tapes in the machine idling.
I am concerned about your heads clogging up - that is not normal unless you don't take proper care of your tapes - is there very high humidity in your area? That could cause problems.
Sorry I posted this in a hurry but will go into more detail later if need be.
Porsche Parts.
May 27, 2012 | JVC 32 Class 1080p 60hz Lcd Hdtv - Black...
How do you load paper into a canon p23-dh v
For loading paper into canon p23-dh v is to cut a piece of index card to the length of 3 inches and to the width of the paper you want to load. Tape evenly to the end of the paper roll and put into the ****, pushing gently in and at the same time pressing the 'Feed" button. It will immediately feed since it is firmer than the Poat-it paper.
Apr 26, 2010 | Canon P23-DH Calculator
Loading paper into an epson stylus tx110
hi there... this is what you need.
Loading Paper Follow these steps to load paper: step_1.gif Slide the edge guide to the left. ha5280001h.gif step_2.gif Fan a stack of paper, then tap it on a flat surface to even the edges. step_3.gif Load the paper with the printable side up, against the right side of the sheet feeder. Then slide the left edge guide against the left edge of the paper, but not too tightly. ha5280002h.gif ha5280003h.gif mark_no.gifNote: Leave enough space in front of the printer for the paper to be fully ejected. Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures. Make sure the paper stack fits under the fon4_99.gif arrow mark inside the left edge guide.pls vote for me
Mar 09, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Loading paper into a 1205-3 Victor calculator?
I just got the same calculator without a manual. Fold over one corner of the tape so it almost goes to the other edge of the paper, making a 45 degree angle. Insert the tip of the tape into the slot at the back of the calculator and push it ahead until the corner goes under the black plastic part. I had to push it ahead a little more until it was starting to come upward on the other side. Push the arrow button at the top left corner of the keypad to advance the tape.
Jan 25, 2009 | Victor 1205 Calculator
DV Deck not loading tapes...wtf
most likely problem is a defective cassette housing. good service tech should be able to handle this with no problem.
Aug 29, 2008 | Panasonic AG-DV2000 Mini DV VCR
Loading paper tape
Well, I just had a long and vigerous fight withmy new HR-8TM. I came here and read all the before mentioned solutions. Then the idear struck me. Instead of cutting the paper even all the way across the roll, I cut it slanted on the sides and straight across the middle " __ " and guess what it passed the roller feed through.
It worked for me, maybe it will work for you.
Apr 10, 2008 | Casio HR-8TMPlus Calculator
Poor recording at start of tape
Hello. This kind of sounds like the loading deck is a few teeth out of time. In other words the tape is not fully dropping down. When the drives start pulling at it the first few minutes of playing it probably seats down a little further and a little further until it finally bottoms out and seats correctly. This I have seen before. The timing issue can result from pushing a tape in a little hard at times instead of letting the loader pull it in itself after it makes its first switch. At some point the loading deck went out a tooth or two and has remained that way ever since. Putting one of these loading decks back in "time" provided there is not any damage to the loading gears should be handled by someone experienced with this. If your familiar with gearing it would simply be a matter of marking the gears when you "trick it" to load a tape. The metal tape retainer should hit bottom when it drops in. When you start your re-timing process you only go one tooth at a time until you finally get it to hit bottom. You should not go a tooth more because you may cause damage to the main gear or one of the others. Good-luck and hope this helps.
Jan 13, 2008 | RCA VR637HF VHS VCR
Tape keeps ejecting - panasonic nvfj620
Is it only the Head cleaning cassette which keeps getting ejected, or is it happening with every tape you insert? Was the Head Cleaning Tape a little tight in the Cassette compartment? Did you have to put some pressure to push it in or did it come out with difficulty? From your symptoms, it looks like there is a gear timing problem with the cassette loading compartment gears. It could also be due to some obstruction inside. try shaking the VCR, and if you are hearing some noise, Open cover and check for foreign objects.
Apr 25, 2007 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Casio HR-8TMPlus Calculator Logo
209 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
