Question about Siemens Washing Machines
Siwamat 6110 stops with a flashing light half way through the second rinse.
3 Suggested Answers
SOURCE: wf540g flashing lights power and half load
I have a hotpoint wf440 with the same fault. An engineer called and said it was a defective computer board. He said it would cost £90 for the part. I found it at http://www.emwelec.co.uk/ for under £50. I have ordered it and will fit when it arrives and let you know!!
Posted on Dec 03, 2006
SOURCE: flashing power light and rinse hold light
This is not exactly the same light sequence,but if the crease guard light and the on/off light are flashing ,check the drain pump as I solved the problem by removing an underwire bra wire from the pump.
Posted on Jan 26, 2008
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Dark blue display on nokia 6110
dear just flash 6.2 ver.or chek sp data ur phone 100%ok
Aug 01, 2012 | Nokia 6110 Navigator Cell Phone
My dishwasher will start any cycle then half way
The touch pad has gone bad. Common problem with the GE made dishwashers.
May 12, 2010 | Dishwashers
F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
Sep 15, 2008 | Washing Machines
SIWAMAT 6102 (GB) Code 3 Flashing. What does this error mean
The pump was working but not pumping. The rubber hose from the bottom of the drum to the pump was removed and found to be partially blocked. The debris inside the rubber hose was cleaned out and reassembled with no further problems.
Sep 07, 2008 | Siemens Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Flashing power light and rinse hold light
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
122 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
