Question about NorStar BCM-T7208 Corded Phone
M7208 I have just put a refurbished phone on an existing extension, however when I attempt to retrieve that extension it states "not in service". We also have three other extensions on my switchboard showing available but again when I attempt to give that phone that extension, the same message occurs. The display also does not show the date and time completely it is like a watch that has run out of battery or water in it. Thanks
    Sergeant:
  • 209 Answers
Dear Sue Johnson
Right, well immediately you have given me a symptom of a fault with the LCD (Liquid Crystal Diode display), and my guess is that if the display is not liquid induced or that it is not broken, then the only thing left to rule rule out is power failure to that part of the circuitry. Now i would have tothoroughly investigate why this happened before i could pinpoint exactly what the fault is, but a good guess would be either bad refurbishment, or liquid induction/ ingression previously has damaged components.
Now about the extension problem, I wouldstart off by stating that the refurbed portion of the system may have malfunctioned again or even elsewhere on the device, which may or may not have been directly caused by refurbishing involvement.
Im guessing that either your switchboard controller is faulty, or possibly a fault somewhere in the switching equipment that is in direct relation to data transfer over the RJ45 connectors (standard phone/ network cable type connection)
Your best bet is to remove all of the phones on the extension/ switchboard and then install them one-by-one and see what errors are thrown up, the ones that cause you a problem and then tackle the switchboard with the direct fault.
If all of this is to do with the phone (s) and not the switchboard, then i would say, remove the phones, replace them with a similar type and then notify someone like myself who may be able to advice you on your next best course of action. But if yor phone network is that valuable, then i strongly suggest selling the broken phones for spares / repairs and using the money to at least cover part of the cost of purchasing new ones of the same make and model as the ones on the rest of your local system.
The same will obviously apply to the switchboard, unless there are user servicable components inside, or you are particularly handy with electronics, comms technology and a soldering iron.
In the mean time, I wish you all of the best luck, and I hope to hear more about this situation soon, I also look forward to helping you the best i can with regards to this matter.
Yours sincerely
oz
P.S.,
Im logged on here 24hrs 7/365 days year now, so if you need advice, then im only a click and a few questions/ comments away
Posted on Apr 10, 2008
Our phones have been working fine without incident for almost 5 years, as is.We no longer have the Administrative Switchboard, as our phone system was separated between two offices. This morning, with no...
Programming for the voice mail is done on M7310, M7324, or T7316e sets. Try finding one of these sets around the office to do the administrative programming.
Sep 03, 2013 | Nortel Meridian M7208 Corded Phone
How do I change the internal extension number of my Nortar M7208? Thanks, Chen
In programming mode, under System Programming, "Change DN". You must choose an unused number within the available range of extensions of your system.
Aug 11, 2010 | NorStar M7208 Corded Phone
HOW TO RETRIEVE VOICE MESSAGES? DOES THE PHONE DISPLAY YOU HAVE A VOICE MESSAGE? IF NOT, THEN WHAT IS THE FEATURE CODE TO ENTER AND OBTAIN MSGS.
The display on a Nortel set will say "message for you" if there's a message in your mailbox. To access your voicemail you can press your open voicemail key if its programmed or press feature 981.If you wish to retrieve your messages remotely, call your office, when the autoattendant answers the call press ** followed by your extension number, your password then # (ex. **2231234#).
Jul 09, 2010 | NorStar M7208 Corded Phone
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Sep 21, 2009 | NorStar M7208 Corded Phone
How do I retrieve recent incoming calls
If you have call log set up you can access the log log by pressing feature 812. To program that feature as a one touch button press feature *3, press the button you what to be call log and enter feature 812
Mar 27, 2009 | Nortel Meridian M7208 Corded Phone
Nortel M7208 Swapping phone equipment but keeping the extension
There is a built-in feature called Set Relocation. Check with your system administrator to make sure this feature is set to No. Then you can swap phones without a problem. Good Luck!
Aug 05, 2008 | NorStar NT8B30 M7208 LCD Speakerphone -...
Norstar M7208 telephone
This could be because you have several mailboxes/extensions set up. We've had the same problem in our office.
As a result, from the phone that reads "Messages for you" you can find out which mailbox is attached to the phone.
1. Press "Feature"
The display will read: "Set: ???"
The numbers shown in place of the question mark will be the numbers to the mailbox attached to the phone.
2. Press "Feature"
Enter 981 for voice mail access
The display will read "Login: "
Enter the numbers from the previous action, and if you don't know the password, attempt to use the default passwords of 0000 or 1234.
This worked at our office. I hope it works for you.
If not? We find the site http://nortstarsupport.com VERY helpful.
If you don't know the password, but have access to the system administrator login, you can reset the password for the set you are trying to retrieve messages.
Good luck
Jul 14, 2008 | NorStar Lands Phones
NorStar BCM-T7208 Corded Phone Logo
241 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
