Question about Ximeta NetDisk (NOWWL) 160 GB Hard Drive
Can usb substitute for the ethernet connection?
We have a Netdisk that was connected to the router (and through it to our two computers on a home network) via the Ethernet cable. The Netdisk worked fine until its router port failed. We have tried to bypass the bad Ethernet port by connecting the netdisk to the router via a USB cable. Netdisk works fine if it is connected to our computers by the USB cable. But, when connected to the router by the USB cable, our two computers cannot access Netdisk. We get a black box saying Netdisk is disconnected. We are wondering if it is possible to use a USB cable to connect Netdisk to the router. Or, do we possibly have to reinstall software? Any ideas?
Perhaps buy one on eBay (possibly $60) and pull it's interface circuit board, to replace your bad one:
http://search.ebay.com/netdisk
Posted on Jun 07, 2008
  • 1 more comment
  • NanooGeek Jun 07, 2008
    Oh yes ... and while you are at it, could you send me the surplus hard drive (from your eBay purchase)... My NetDisk 160 has begun to sound like an old fluorescent magnetic ballast (... due to vibration) . Mine contains a Samsung SP1604N ((according to old Everest Home Edition 2.20.405, but it won't access the SMART info).
    HD HeartBeat 2.0.2.11 (PCMag Utilities) sees that the drive is SMART capable, but claims SMART is disabled. Hmmm, I suppose Ximeta may be tracking drive health some other way ...
  • NanooGeek Jun 15, 2008
    Another possibility is to just replace the enclosure (assuming the drive isn't too old ). www.kleggusa.com aquired the NetDisk brand from XiMeta in early May, and have been selling units at very low prices. Look under Products, Klegg Netdisk Mega (or Giga, if your ethernet will support that).
    At the Klegg website, enclosures had been marked down to $20, but I no longer find any trace of them there. There are still some available for $25 and up:
    www.amazon.com/s?ie=UTF8&keywords=Ximeta&search-type=ss&tag=therefusal4793-20&index=electronics&link%5Fcode=qs
    ... a more direct answer to the subject: "good luck!".. Plugging it into the USB port (assuming you put the DIP switches down on the back of the enclosure, if it is an older NetDisk) still leaves traffic going over ethernet. The enclosure may not know what to do with ethernet traffic coming over the USB port. If it does, and the ethernet router is smart enough to fool the NDAS driver on your computers, you might get lucky...
Can I connect my Pocket Wi-Fi to a Router with USB Port so that I can share my internet connection to my other computers.
Normally any new router with a USB port is only for USB memory sticks to share file across the network. Not for feeding internet into the unit (router).
It should be possible if you had a wifi "repeater" with Ethernet outlets, if what you are trying to do is hard wire the other computers.
The pocket wifi would wifi to the repeater, then the repeater would feed the Ethernet to the computers.
Jan 21, 2015 | Computers & Internet
Ximeta ndas not connecting
Check the cables first, try a different one
May 26, 2008 | SmartDisk NetDisk (END160) 160 GB Hard...
Tip
Connecting Two Computers Directly With Cable for a home network
The simplest and easy way to start a home network
The simplest kind and easy to maintain of home network contains exactly two computers. You can use this kind of network to share files, a printer or another peripheral device, and even an Internet connection. To connect two computers for sharing these and other network resources, consider the options described below.
The traditional method to network two computers involves making a dedicated link by plugging one cable into the two systems. Several alternatives exist for networking two computers in this manner: Ethernet crossover cable
Null modem serial cable or parallel peripheral cable
Special-purpose USB cables
Ethernet - Of the above choices, the Ethernet method is preferred as it supports a reliable, high-speed connection with minimal configuration required. Additionally, Ethernet technology offers the most general-purpose solution, allowing networks with more than two computers to be built fairly easily later. If one of your computers possesses an Ethernet adapter but the other has USB, an Ethernet crossover cable can still be used by first plugging a USB-to-Ethernet converter unit into the computer's USB port.
Ethernet crossover cables
Serial and parallel - This type of cabling, called Direct Cable Connection (DCC) when using Microsoft Windows, offers lower performance but offers the same basic functionality as Ethernet cables. You may prefer this option if you have such cables readily available and network speed is not a concern. Serial and parallel cables are never used to network more than two computers.
USB - Ordinary USB cables must not be used to connect two computers directly to each other. Attempting to do so can electrically damage the computers! However, special USB cables designed for direct connection exist that can be used safely. You may prefer this option over others if your computers lack functional Ethernet network adapters.
To make dedicated connections with Ethernet, USB, serial or parallel cables requires
each computer have a functioning network interface with an external jack for the cable, and
the network settings on each computer appropriately configured
One phone line or power cord cannot be used to directly connect two computers to each other for networking.
Connecting Two Computers with Cable through Central Infrastructure
Rather than cable two computers directly, the computers may instead be joined indirectly through a central network fixture. This method requires two network cables, one connecting each computer to the fixture. Several types of fixtures exist for home networking: Ethernet hubs, switches, and routers
USB hubs
Phoneline and powerline wall outlets
USB hubs
Implementing this method often entails additional up-front cost to purchase more cables and network infrastructure. However, it's a general-purpose solution accommodating any reasonable number of devices (e.g, ten or more). You will likely prefer this approach if you intend to expand your network in the future.
Most cabled networks utilize Ethernet technology. Alternatively, USB hubs can be employed, while powerline and phoneline home networks each offer their own unique form of central infrastructure. The traditional Ethernet solutions are generally very reliable and offer high performance.
Connecting Two Computers Wirelessly
In recent years, wireless solutions have enjoyed increasing popularity for home networking. As with cabled solutions, several different wireless technologies exist to support basic two computer networks: Wi-Fi
Bluetooth
infrared
Wi-Fi
Bluetooth
infrared
Wi-Fi connections can reach a greater distance than the wireless alternatives listed above. Many newer computers, especially laptops, now contain built-in Wi-Fi capability, making it the preferred choice in most situations. Wi-Fi can be used either with or without a network fixture. With two computers, Wi-Fi networking minus a fixture (also called ad-hoc mode) is especially simple to set up. How To - Set Up an Ad Hoc WiFi Network
Bluetooth technology supports reasonably high-speed wireless connections between two computers without the need for a network fixture. Bluetooth is more commonly used when networking a computer with a consumer handheld device like a cell phone. Most desktop and older computers do not possess Bluetooth capability. Bluetooth works best if both devices are in the same room in close proximity to each other. Consider Bluetooth if you have interest in networking with hand held devices and your computers lack Wi-Fi capability.
Infrared networking existed on laptops years before either Wi-Fi or Bluetooth technologies became popular. Infrared connections only work between two computers, do not require a fixture, and are reasonably fast. Being very simple to set up and use, consider infrared if your computers support it and you lack the desire to invest effort in Wi-Fi or Bluetooth.
If you find mention of an alternative wireless technology called Home RF, you can safely ignore it. Home RF technology became obsolete several years ago and is not a practical option for home networking.
Try it is the best home network option.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Can I connect canoscan 4400f using ethernet cable
i believe is not possible to connect to a router. printers ar designed to be connected to computers via ethernet cables and bluetooth when both devices are bluetooth enabled.(must have a wifi bluetooth ethernet card installed or usb bluetooth installed via usb). is you want to have the printer to be used bye more than one computer at home or office. you must set up each computer to the printer as well.. in control panel look for printers.then set up the conections.if computer 1 is printing a document. computer 2 will have to wait. when done. then will print work for computer 2.
Dec 18, 2012 | Canon CanoScan 4400f MultiFunction Color...
Setting up home network one computer has ethernet and one has usb, router is ethernet how can i connect older usb port on computer to ethernet router
The following should fix your problem. This one is available at Radio Shack. You can typically get them at most electronic retailers... Fry's, Radio Shack, etc...
BelkinĀ® F5D5050 Ethernet-to-USB Adapter Model: F5D5050' Catalog #: 55009874
Sep 30, 2010 | Compaq Presario Modem/NIC Combo...
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Netgear 624
to set upa network
http://lifehacker.com/software/wifi/geek-to-live-set-up-a-home-wireless-network-162754.php
there is no "earthnet" connection. it is an ethernet connection. it looks like a phone cable but has larger ends than a phone connector. the router is connected to the computer via an ethernet cable if it needs to be hardwired to a ethernet port or internal ethernet card. a wireless connection only needs to be an add-on internal card w/antenna or a usb connector hub (it looks like a usb flash memory stick)
here is how it's done. netgear has the same type setup.
Oct 13, 2008 | NetGear WGT624 Wireless Router
Can't get internet access!!
The proper procedure in any router based network is to get the router on the network first. Plug it into the online cable modem and boot it up. Let it sit for a minute and then boot up wired computers one at a time. Use one of the wired PC's to get into the routers GUI (eg. 192.168.1.1) and see if WiFi is turned on and the permissions or wireless access is not being blocked by any security settings like MAC address or IP filters. It should be wide open. You dont need ANY drivers for a router on a PC unless they are USB drivers for a USB connection straight to the router, never seen one but I have seen a cable modem/router that had a USB connection. If your laptop has a USB wireless device, you need to load the drivers for that onto your laptop, but if it is using the built in ethernet port on the rear or a PC card ethernet card, you just need to plug the ethernet cable to the rear of the router and boot up. Make sure your ethernet device is enabled in windows and you should be good to go. After you gain access to the internet on the wireless device, get back into your router, prefferably on the wired computer and lock your network down with security measures like MAC address filtering, WEP, or other means.
May 16, 2008 | Compaq Computers & Internet
XiMeta's NDAS NetDisk and Windows Vista Blue Screen
Take a look at this: http://www.ximeta.com/forum/viewtopic.php?t=13. The patch from Microsoft worked for me.
Feb 20, 2008 | Ximeta (NDU10200CU)
Ximeta NetDisk (NOWWL) 160 GB Hard Drive Logo
303 people viewed this question
Top Ximeta Computers & Internet Experts
John Bowen
Harry
Harry
Level 1 Expert
Dick Monti
Dick Monti
Are you a Ximeta Computer and Internet Expert? Answer questions, earn points and help others
