The replacement will do the same thing...damned Frigidaire/Electrolux needs to redesign this part with a lot more strength. This is just pitiful when my weakling wife breaks two of them within a year's time.
To replace the part, pry loose the snap-in tabs at the bottom of the
face trim. Raise
the face trim straight up until the upper trim hooks
can be pulled forward out of the mounting slots. Remove the three
screws that hold in
the dispenser mechanism, move it
forward and pull out the
ribbon cable
from the circuit card. Unplug the modular plug on the left side of the
board...watch out for 120VAC!! Loosen the two screws and retaining
plates...rotate the left plate 180 degrees, and remove the right one
completely. Unplug the water dispenser LED connector from the
circuit board.
Lift the spring off of the plastic water dispenser arm, and remove the
dispenser lever by moving it slightly up, then back and then down
behind the loose dispenser assembly.
Installation of the new part is the reverse of the above procedure.
I've repaired an old broken one by installing a screw through an angled hole in the illuminated lever extending up into a smaller, threaded hole in the clear plastic pivot injection mold. Then, I epoxied the hell out of it, and after the epoxy setup a bit, I tightened the screw one turn to put a bit of tension on the repaired assembly. Then I layered on some more epoxy on the front and the back of the broken joint. I'm letting it cure up as I write this, and I will soon see if I have any success putting this into service.
Epoxy alone is just not strong enough given the shear and tension forces present at the weak spot that breaks.
Frigidaire/Electrolux: how about a decent fix for this problem???
