Washing machine overfilled twice (maytag) repaired once but did it again within 4 months
    Genius:
  • 1,073 Answers
Three things can cause this deffective water inlet valve, deffective water pressure switch and a pressure hose that connects to the pressure switch to the tub, has to be one of the theree things
gl
Posted on Apr 10, 2008
How do you clean a Maytag Neptune top loading washer
Tip: Prevent a Smelly Washer With Powdered Dishwasher Detergent
I have a great tip for making a smelly clothes washer smell fresh and clean, given to me by a Maytag repairman. Simply run dishwasher detergent powder, not liquid, through your machine with no clothing in it, about once or twice a month.
It works and it is cheaper than the specialized products that do the same thing. Use the same amount you would use of laundry detergent for your particular machine.
Aug 16, 2015 | Maytag Neptune Washing Machines
Splendide WD2100XC - The vent from machine to outside keeps plugging with lint. I cleaned it once - having to haul out the unit to do it, which was no easy task - and, now, within a few months of cleaning...
Maybe fan is not working properly, or restricted vent in the first place, causing it not to flow properly and lint gets hung up. Is vent hose fairly straight or does it go around a lot of curves?
Sep 07, 2011 | Splendide 2000S Vented Washer/Dryer
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
I have a maytag neptune washer top load the washer stays in wash cycle and will not go to next cycle.
Clean out the pump. Ours was doing that as well, when our mechanic looked at it he could find nothing wrong with it so he looked at the pump and it was full of mud and junk. He said once it is cleaned out you have to run it twice a month empty to keep it clean. Ours has worked great since.
Apr 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
Power head and wand has no power. Unit is less than 4 month old.
Hi, I had the same problem with mine and found that if you plug the power head directly into the handpiece (bypassing the telescopic wand) and it worked only proved the problem is in the telescopic wand. The problem as I found was a broken terminal in the end that connects to the powerhead (female socket). As it is a non repairable part means replacement at $100AUS I have had my machine for 3 years and in this time have replaced the both powerhead once and the wand twice within 2 years of owning the machine. The wand has now gone faulty again 4 months after replacing it and consequently Electrolux only warranty spares for 3 months which I think is poor! Its a great machine but a little too delicate even if it is only used for domestic operations once a fortnight! I paid $700 for my Oxy3 3 years ago and wont be buying another Electrolux product due to poor service (customer and product):((
Dec 22, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Wont spin. Called repair person, he said the "transmission" was not working and would cost $300 plus to fix. I paid $470 for the machine new may 2009. I thought washing machines lasted longer...
before we go to far you said the machine is only 19 months old if this is the case it should still be within warranty as all new machine have a standard 2 year warranty from the manufacturer where they will foot the bill for any repairs, if it cost u 470 and yor gonna pay 300 to fix it? its kinda a no brainer (no offense intended). think long term if it breaks jus once more and needs to b fixed and it costs over 170 you've just paid the same amount as it cost for a new one and if its breaking down at 19 months it is definatly gonna breakdown again. my professional advice go buy a brand new washer with an extended warranty, most people think extended warranty's are a trick to get you to pay an extra 50 bucks but it is well worth it in the long run
Nov 16, 2010 | Maytag Centennial MVWC700V Washer
My washington machine water smells horrible, but not the water in the rest of the house. It all enters the house through the same pipe from the municipal water supply. Could there be something within the...
You probally have a front load washing machine. There is probally mildew in the wash tub & discharge hoses. Try washing an empty load with a hot water and a cup of vineagar and see if that helps with the odor. If it does, then repeat this once a month.
Jul 20, 2010 | Maytag Washing Machines
Washing Machine Leaked but seems ok now.
likely it was overfilled - and caused an unbalanced load that may have shifted the tub - allowing the gasket to leak.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
