Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
I have err 99 any solution?
Ive had my canon eos1000d for about a year and this weekend i have err 99. any solution?
  • Canon Master
  • 2,517 Answers
.1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99' message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99' message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99' message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99' with a different Canon lens attached, then the
camera should be serviced.
Posted on Jun 08, 2010
Error 99 with a Canon 300D (original rebel) and Tamron XR Di II 18 to 200 mm lens. Occurs when lens is zoomed out. Does not happen with other lenses (Canon 18-55 kit, Canon 75-300). Cleaning contacts on...
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 17, 2011 | Tamron AF 28-200mm f/3.8-5.6 LD Aspherical...
Err 99 keeps coming up
It is due to some kind of electrical (contact) failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
May 16, 2010 | Canon EOS 40D Digital Camera
I receive Err 99, it says to re install battery or
It is due to some kind of electrical contact failure.
May 14, 2010 | Canon EOS 40D Digital Camera
Canon EOS Xt displays Err 99 how do I fix it.
change the lens or try cleaning the connector tabs with a eraser.
Jun 26, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 appears after every click for canon eos 30 D
Err 99, but lens-to-body problems are common- thought error 99 is a bit of a catch all- generally a lens and body conflict. And also Err 99 means that something wrong happened, but then it cleared out before it could be further determined.
Here is the blurb from canon to try:
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
Does the "ERR 99" message appear? If so, then the CF card is the most
camera body.
If the "ERR 99" message only appears when one particular lens is
If you see the "ERR 99" with a different Canon lens attached, then the
For factory service, forward your digital camera (remove the CF card
and battery) properly packaged and insured, with a letter describing the
difficulties. Be sure to include your name, address, telephone number,
and proof of warranty (if applicable). Send to the Canon Factory
Service Center at the following address:
Canon Factory Service Center
100 Jamesburg Road
Jamesburg, NJ 08831
Tel.# (732)521-7007
or
15955 Alton Parkway
Irvine, CA 92618
Tel.# (949) 753-4200
Your equipment will be examined and you will be advised of the
findings.
The length of time for the repair will be dependent upon the nature of
the repair and availability of parts if needed. If the repair entails
something that is not covered in warranty you will be sent a written
estimate to the address that you have provided.
Please leave for me, a rating...
May 15, 2009 | Canon MF8180C Color Laser MFC Printer
I took my EOS1000D on holiday took two photo's now all I get is ''BUSY'' on the display
I can help you fix the BUSY Error or Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
May 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Err 99 in canon 350D
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 400D SLR - Err 99
Try going into the menu and turning off the lock for shooting without a lens. Then try firing it without a lens to see if it works. Very often a lens problem can cause the Err 99 message.
Also, check to make sure the pop-up flash is not stuck down. That could also cause it.
Unless you have used your camera a LOT, it shouldn't be a bad shutter. They usually only quit after many years of use. I think Canon quotes 125,000 shots as the normal life of a shutter in a digital SLR.
CameraRepairs
Jul 14, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
My Canon is displaying - Err 99 what should I do?
A common cause of Err 99 on the Digital Rebels that have some age on them is shutter failure. There is a switch called CN2 in the shutter that fractures and causes either bad flash sync or shutter failure-or both. The repair is to replace the shutter. Sometimes the CN2 switch can be repaired but we find at our shop it's better to replace the shutter with a new one. That way, with a new shutter, you will get years more of good service from the camera.
There are other causes for Err 99. Check the electrical contacts on the rear mount of the lens and the coresponding contacts in the lower portion of the mirror box in the camera body. Make sure they are clean and not distorted or bent.
There are more but these two are, by far, the most common.
Dec 03, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
483 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
