Loosing DSL Connection (follow up)
I already made a complaint to the DSL service provider,they told me that my location is far from their cabinet that is why im loosing connection, but there are 2 of us connected to that same cabinet but the other one has no problem with his connection.the technician told me to install a blower to cool the router coz there are 4 PCs connected to it.it (the blower) seems to be working coz now i don't totally lose connection unlike before,do you think there a problem with the router?
    Sergeant:
    Champion:
  • 427 Answers
What brand is your router? What is the product number?
Posted on Apr 10, 2008
Connection to internet
To make an Internet connection 1.Open Network Connections 2.Under Network Tasks, click Create a new connection, and then click Next. 3.Click Connect to the Internet, and then click Next. 4.Choose one of the following:
• If you already have an account with an Internet service provider (ISP), click Set up my connection manually and then click Next. • If you have a CD from an ISP, click Use the CD I got from an ISP and then click Next. • If you do not have an Internet account, click Choose from a list of Internet service providers (ISPs) and then click Next. 5.From your choice above, click one of the following:
• If you are connecting to your ISP using a standard 28.8 Kbps, 56 Kbps, or ISDN modem, click Connect using a dial-up modem, click Next, and follow the instructions in the wizard. • If your DSL or cable modem ISP connection requires a user name and password, click Connect using a broadband modem that requires a user name and password, click Next, and then follow the instructions in the wizard. • If your DSL or cable modem ISP connection is always on and does not require you to type a user name and password, click Connect using a broadband connection that is always on, click Next, and then click Finish. Use the CD I got from an ISP
• Click Next, and then click Finish. Insert the CD provided by your ISP and follow the instructions. Choose from a list of Internet service providers (ISPs)
•To create an Internet account using MSN Explorer, click Setup Internet access using MSN Explorer (U.S. only), and then click Finish. Follow the instructions in MSN Explorer. •To choose an ISP, click Select from a list of ISPs, click Next, and then click Refer me to more Internet service providers. In the Internet Connection Wizard, click Create a new Internet account, click Next, and then follow the instructions in the wizard.
Feb 14, 2017 | Internet Computers & Internet
Hello, I keep loosing internet connection, how can I tell if there is a problem with the modem?
try to check the status of the lights on your modem. Try to check the light in globe icon, that is the icon for your Internet status, if is GREEN it mean to say that it has connection. When it turns to RED, check the DSL light if it is in SOLID GREEN, When it blinks try to check it with your Service provider.
May 29, 2011 | Zoom X6 (5590) DSL Modem (55900003)
Asl light blilnks and i get error message saying low or no connectivity
This error occurs when your ISP 's(Internet Service Provider) server is partly down or either way. Or it might occur when the DSL wire got any loose connection or cut. Try checking the DSL cable and if still the problem exists, complaint your ISP to check on their side. Thank You.
Jun 30, 2010 | Computers & Internet
Everthing is connected but power light is red and not green.
I'm sorry I cannot completely solve your issues here, but this is due to certain details that are specific to your internet service provider, and other details not provided in your request. However, I do have quite a bit of experience with 2Wire gateways and setting them up for use with DSL service. The following is based on my experiences with 2wire gateways, and AT&T as service provider:
There are a many things that could possibly be causing the red power light (which indicates a system error, more details below), and the reason why you have no internet connection. Your very best bet is to call technical support for your internet service provider (or ISP) for DSL service. You likely received this unit from your service provider - if you did, then they will have technicians who can walk you through the setup process for this specific 2Wire gateway. Also, if you received the unit from your service provider, you most likely received a setup CD/DVD for setup on your pc. If you have not already run this setup disk, do so prior to contacting technical support, and check the status of your lights / internet connection again prior to calling tech support. Depending on your service provider, if you did not receive a CD/DVD from them to setup internet service, then you most likely can find a download of the setup utility available via their website...just go online and see if you can find it on their specific website,& if so, download and run the setup utility. Only run the setup utility on a pc connected directly (by ethernet cable) to the 2Wire gateway, unless directed to do otherwise by your service provider, or their setup utility's instructions.
If you did not receive the unit from your service provider, then you should contact them asap to find out: A) if they support the 2wire gateway (give them the model number), and if they do support it, B) find out what is required to set it up for use with their service.
According to the manual from the manufacturer, available here , when your power light is lit solid red, it indicates the following: "system error, contact technical support". You need to contact technical support for your Internet Service Provider (such as AT&T DSL), NOT for the manufacturer.
If you have your PC connected to your 2wire unit, and the unit is powered on, you can access the unit's setup utility via your web browser (please ensure you have Internet Explorer 5.5 or later, or Mozilla Firefox 3.2 or later). Open your web browser, and in the address bar type the following:
http://gateway.2wire.net/
Click the system tab to open the System Summary page. The diamonds should be green or red, indicating the status of your LED's on the light panel of the 2Wire unit. It may give you only the status message I indicated above, or could provide you with more info. I maintain that you should first contact your ISP's tech support, but if you have not already accessed the gateway's setup utility and run the setup wizard, you may do so from the System Summary area. Look to the far right of the page, and you should see the Setup Wizard utility link in the lower right-hand portion of the page. Links for other registration info are also in this section, if available. Follow the on-screen instructions and check your status lights again.
Again, I hope this information helps, and again, your best resource is the tech support team for your internet service provider. Best of luck, and please report back to let us know if you get it set up, or, if we can be of further assistance to you in any way.
May 25, 2010 | 2wire 2700HG-B Router (2700HGB)
Hi, i have wnr2000 and am trying to set it up. i'm at the setup wizard which says that i already have a valid internet connection. what does this mean and what do i do next?
Basically you need to sign up with an Internet Service Provider in your area. The ISP will advise you the type in modem/Internet connection you need for their service (ie. DSL or cable) and advise you or provide you with a compatible DSL or cable modem. The ISP will provide an installation disc or instructions to configure the modem so it connects with their Internet server.
The modem is then connected to the wnr2000 router's Internet/WAN port with a LAN cable.
If you have already configured the modem and connected it to the wrn2000 router and the setup wizard has detected that you already have a valid Internet connection (it has detected your TCP/IP address which your Internet Service Provider has given you - this IP address is your unique network address - it is similar to your house address in your street, in your suburb, in your state, and in your country). Just click OK and continue with the setup.
Oct 30, 2009 | NetGear WNR2000 Wireless Router
Thinkpad 760el how can I connect broadband preferably wired
You will need a LAN network card in your laptop, it may already have a LAN port connection on the laptop.
First you need to decide what type of broadband connection your require DSL (it uses your phone line) or a cable connection.
You need to signup to an Internet Service Provider in your area that can provide a DSL or cable connection. Select a broadband plan that suits your requirements, be aware that some ISP will charge additional fees for exceeding your monthly download limit.
The ISP may also include a DSL or cable modem with their broadband plan.
The ISP will supply a setup CD to install and setup your broadband connection.
Oct 25, 2009 | IBM Computers & Internet
I can't figure out how to set up my wireless internet.
To setup a wireless Internet connection you need the following :- 1. You need either a cable or DSL modem with a wireless router or a 3G wireless modem that connects to a 3G wireless network. 2. You need to signup with an Internet Service Provider. The Internet Service Provider may also provide this modem at a cost. 3. The Internet Service Prodider will provide an installation instructions/CD as well as E-mail setup. Have you already installed the wireless card driver on your computer? Can you give me details of what you have already done in regards with setting up the wireless access.
Jun 14, 2009 | Acer Aspire 5610-4648 Notebook
I have an AT&T Modem; having trouble with internet connectivity
It is OK to keep putting the UN and PW in. However you shouldn't have to. I suggest having a tech come to your home and have them do a signal test both at your jack and outside with your home unplugged from your service box. If there is a big difference in the numbers then you're simply loosing signal due to signal bleed inside. This is a simple fix. Have them isolate some wires in your jack and place a DSL filter outside. Then your DSL signal will go straight to your modem and not bounce all over your home. This will NOT affect your phone.
Dec 31, 2008 | AT&T High Speed DSL Modem
Intermittent ADSL connection
The DSL light blinking or going out indicates that the DSL modem is loosing sync. This is usually caused by noise on the line. When you get the DSL service you should be given filters to put on all of your phones so that the phones will not interfere with the DSL signal. Those filters need to be attached to anything connected to the phone line that has the DSL on it except for the DSL modem. Other than that the problem could be on the service providers end, something outside your home, or the DSL modem going out. I would suggest that you verify everything is filtered, then contact your service provider so they can run test on your DSL line.
Dec 23, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Loosing DSL connection
Call the DSL service provider and tell them to fix the problem because it is obviously a problem on their end. Besides, why would you pay so much a month for that service, if you cant use it all of the time?
Apr 10, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
