Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Opening the monitor
Can you tell me how to open the monitor so I can try this
Thanks
  • 472 Answers
These are a snap to open.
Put a towel on a flat surface like the dining table.
Remove the 2 screws that hold the stand in and slide the stand out of the hole.
Remove the screw in each of the 2 bottom corners.
Remove the screw in the middle at the bottom (it was under the stand to begin with but some do not have it for some reason.)
Now comes the easy part.
Put a few fingers onto the section the power plug goes into.
Tuck your thumbs into the hole left by the stand.
Push into the power plug section downwards with your fingers at the same time pull upwards with your thumbs. The rear panel should pop up. Gently pop it all around the edges.
Hope that helps =)
Posted on Apr 12, 2008
Can someone tell me how to open the case of my Samsung 932BW? There are no screws on the back or front. I need to open it up to take a look at the capacitors. Thanks.
1.follow this first
2.Turn the monitor so the front section is facing
upwards. after completely pulling this front cover,
Turn the monitor so the back of it is facing
upwards. Lift up and remove the back cover.
Sep 27, 2010 | Samsung 932BW Monitor
Monitor says "no signal" and won't boot up
Graphic Card Error - Loss Of Processor - Replace With Good Graphic Card
Sep 19, 2010 | Acer X193W LCD Monitor
LG1917S-BN Access to power supply - Rear cover removing
You need to use flat thin blade screw driver to crack open the case, starting at the bottom edge of the case first, you may need two screw drivers, when it starting to come apart, leave one screw driver in the partially opening section so it not snap back together while you tackle another section of the case. Most monitors cases these day do not have small slot to show where you should crack open the case at, they just do not want you to fix it.
Feb 23, 2010 | LG L1917S-BN 19" LCD Monitor
My HP Ergo 1280 model D2840A displays a black screen
A 1996 CRT CATHODE RAY TUBE MONITOR FROM THE YEAR 1996, 22 YEARS AGO... WOW. A RECORD HERe.
tHERE is a trick to open it, that I will not tell you ! (a lock)
because you'd get huge shocked with the 12,000 volts inside,.
the thing can hold a charge for a long time.
why not inter the 21st Century with a LCD monitor.
gee $20 used,
Jan 28, 2018 | HP Ergo 1280 Monitor
How do you remove the back or open an HPf1903 monitor?
http://www.instructables.com/id/How-to-Take-Apart-a-Laptop/
Feb 11, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor malfunction
Hi!
You might also try to connect another monitor, to check if has the same behavior. In this case the problem is generated at graphics card or from loosen cable connections.
Jan 06, 2009 | LG Flatron L1715S 17" LCD Monitor
How can open the monitor Body (Cover)
hello,
it seems that you open any monitor first time i suggest you to if any screw is not present then not to try to open and if screw is present then remove the screw and remove the base also. then see any lock present on the cover. pull the housing upwards and plz unlock the cover very safety and this you may remove the cover
thanks
ramesh722
Nov 13, 2008 | LG L1717S-BN 17" LCD Monitor
Please tell me, how to disassemble it.
Please do not Open a Monitor, If the issue Exists with the Display Try with another Monitor ... If the same issue exist on more than one Monitor, then Troubleshoot your computer to fix it.
If the second Monitor does great then Service/Replace the monitor.
Opening the Monitor could Void the warranty if you have one upon it.
Jul 14, 2008 | ViewSonic VX924 19" LCD Monitor
Problem with controler
The problem is defective keys/switches of front key PCB.You need to replace this key PCB or Individual keys.
Normally Benq Offers a 3 yr warranty Try contacting BenQ.
Please rate the solution and provide feedback.
Samir
May 15, 2008 | BenQ FP731 17" LCD Monitor
How to remove back cover of monitor
Here are the instructions to open the monitor:
http://josepino.com/?open-samsung-back-cover
"Don't kill yourself just to save some bucks"
Good luck.
Nov 04, 2007 | Samsung SyncMaster 550S Monitor
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
379 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
