Question about Frigidaire CWS3600AS Top Load Washer
Water is leaking out from the bottom
As soon as I turn the washer on to start cycle, I noticed water gushing out of the unit. what could this be and could I fix it myself.
  • 943 Answers
It could also be the pump thats leaking pump is on the right side at the boyyom tip it up against the wall with some water if its the pump you will be able to see it if it leaks replace the pump thanks THE APPLIANCE DOC
Posted on Sep 13, 2008
    Genius:
  • 1,073 Answers
Center tub seal leaking , not easy to change yourself call a pro
Posted on Apr 11, 2008
When I start the washer, it fills just fine with no problems but once it starts the cycle, it gushes water from the bottom of the door
Check the bottom of the plastic inner door. If there is a crack or a gouge, have it replaced. Also check the rubber door boot for holes above the water line
May 09, 2014 | Maytag Neptune MAH5500B Front Load Washer
Kenmore washer 600 series model 11027642600
Could be bad hose, valve or seal in the washer (this was listed under dryers). Requires taking the washer out of service and looking for source of the leaks. Hose, valve or connectors is more likely than a seal if water is gushing.
Jan 11, 2014 | Washing Machines
Kenmore top loader leaking from bottom when loading
could be leaking from your drain pump seal, main tub seal which is between tub and tranny, also your outter tub could have a crack in it! i would remove the base to see inside and run it through a short cycle and see if you can pinpoint the leak
Feb 17, 2010 | Kenmore Washing Machines
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Washer leaks from bottom as soon as it starts filling with water
There are 2 green clips between the top of the unit and the front panel. (you can use a flash light to find them easier). Push on the with a putty knife or small flat head screw driver while lifting on the top. Once the top is open, you will find 2 5/16 screws that hold the front panel on at the top on the right and left hand sides. Once these are removed, you can tilt the front panel forward and see where the water is leaking from.
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Dec 31, 2007 | Dishwashers
Frigidaire CWS3600AS Top Load Washer Logo
110 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
