Battery problem after i unplug the computer, i can't use the battery. it doesn't go on. why?
  • 4,102 Answers
Hi what you mean you cant use battery is it desk top pc or laptop do you mean the battery dont work and you lose the time and date let me know and i give you further assistance ok
Posted on Apr 10, 2008
    Sergeant:
    Champion:
  • 333 Answers
Is this a laptop? If your battery is not holding its charge, the only answer is to replace it.
HP DC7800 doesn't wake up (and power switch does nothing!)
Bad setting. If you press and hold the power button, the computer will shut off. That will keep you from having to unplug it.
Jan 28, 2013 | HP dc7800 Business Desktop Small Form...
Dir-601 doesn't work with windows 8
I don't think it's Windows 8. Connect a ethernet cable fron D-Link to computer. Is your Wireless Adapter Enabled on the computer. Unplug the D-Link, shut down the computer, unplug, remove battery, plug in D-Link , allow it to selftest, plug in computer, boot normally.
Dec 15, 2012 | D-Link DIR601 WirelessN 150 Home Router...
How to repair red screen on asus eee pc sea shell
Remove any discs in the computer.
Hold the power button down until the computer turns off.
Press the power button to turn the computer on. If this doesn't work, proceed to step four.
Remove the battery and unplug the netbook. Wait 30 seconds.
Reinstall the battery and plug in the netbook.
Press the power button for ten seconds. If this doesn't work, proceed to step 7.
Insert the end of a paperclip into the reset button to reset the netbook.
The reset button is a small hole that usually appears next to the USB and other ports.
Windows 7
Create a new Notepad file.
Type this code:
taskkill /F /IM dwm.exe
Save the file as displayfix.bat in the following location:
C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
Restart your computer.
hope this helps
Sep 25, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
Enercell Laptop Battery Charger Doesn't Work When Plugged In?
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
hope this helps
Sep 04, 2012 | Computers & Internet
Password unloking
The simplest way to remove BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
If that doesn't work,you'll need a bios/cmos password recovery tool from http://www.biospasswordrecovery.com
Jun 04, 2012 | Computers & Internet
Need Dell C400 Authentification Password
May 30, 2012 | Computers & Internet
The laptop doesn't start but the charger works.
Take out the battery and connect the charger.
Then try to turn on the computer.
If it works, there is no problem with your computer.
After that insert the battery, plug in your adapter and try turning on once more.
If it doesn't work, you need to get a new battery.
Oct 01, 2011 | Toshiba Satellite Pro L300 Notebook
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
How to discharge battery
"Calibrating" a laptop battery is one way to increase the lifespan of a battery that doesn't last long. The procedure involves two steps: fully discharging the battery, then then fully charging it immediately thereafter. It's important to note that a full discharge doesn't mean you drain your battery until your computer powers off, but rather that you deplete it until it reaches a level of approximately 3 percent capacity, according to BatteryCare.com.
1. Charge the laptop battery to 100 percent. Allow the laptop to sit plugged-in and fully-charged for approximately two hours.
2. Click the "Battery" icon in the lower, right corner of the Windows Taskbar and click "More Power Options." Click "Change When the Computer Sleeps," then click "Change Advanced Power Settings."
3. Scroll down to "Battery" and click the "Plus Sign" icon next to it. Click "Critical Battery Level," then click the arrow to decrease the number to "3." Click "Apply," then click "OK."
4. Unplug your laptop and continue using the computer until it reaches 3 percent, at which point it hibernates automatically. Allow the computer to hibernate for at least five hours, then plug it in and allow it to recharge fully.
I hope you find it very helpful. Thank you for using fixya.
Aug 17, 2011 | eMachines eM3502074 Tablet PC
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
