Question about RCA D52W19 52" Rear Projection Television
  • nightranger9 Apr 11, 2008
    these forums are nothing but a joke all you re interested in is money not help your average joe if i could find a good parts catalog for tv parts i would not even post thanks for no help except for keep asking me to pay for advice
  • 927 Answers
Good Day,
Yes, there may help for you yet.
Let me first comment on your posted 4-11-08 comment I like all of us on forum do don't make any $'s, I'm here to help you all.
Repair: Ensure that there is no holes in the HV wire, clean the surface around the anode at CRT, remove replace the cup and re-silicon cup and area.
Good Luck. God Bless.
Posted on Jun 11, 2008
When testing the hv flyback by turning on the tv, if tv stays on the hv splitter block is bad ,but what if tv turns off what you check next? thanks for the help.
first, I think you have this backwards----if splitter disconnected (look for physical signs or arcing or it burnt) the High voltage would come up and sizzle where it connects to the splitter.
If the set with the splitter disconnected still shuts down it is not the issue---got a D52 of some kind?
Nov 02, 2012 | RCA Televison & Video
Sony 60
Have you check the sleep timer? It could be possible reason why your tv shut off every 30mins. bc the timer was set.
Feb 20, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
My RCA Bigscreen HDTV will not turn on.
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
Removing the HV Wires from Flyback on RCA TV D52W19/
You really dont need it its only a wire.sliice and reconnect.
Feb 18, 2009 | RCA D52W19 52" Rear Projection Television
Replaced parts--here's where we/re at
Check all tubes Red ,Green look for crack or broke some even leak fluid out on board.
Aug 29, 2008 | RCA D52W19 52" Rear Projection Television
Panasonic PT-53WXD63G Flyback, H.O.T., and Triper
The small wires are disconnected at the focus and screen control block, and the large HV cable is disconnected from the HV may have to reuse the large red wire if the new flyback doesnt have the HV lead attached. The Hot is the horizontal output transistor its mounted to a aluminum heat sink near the flyback.
Jul 24, 2008 | Panasonic PT-53WX54 53" Rear Projection...
RCA D52W19 Flyback Transformer
This transformer does not come with the hv lead,if the arch is coming from the side of the transformer,cut the side of the plug were it goes into the transformer and the lead will come out,there is no voltage stored on the hv lead after the set is unpluged for a few min.,the transformer you can get at any rca repair center.
Mar 21, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w19
You can change the HV splitter first,then change the flyback
transformer, if necessary.......Do be careful with part number
of transformer....check the drawing number on it ......10756 =
259296.......10799 = examples..........
I can check on that for you based on your info................T.
Feb 09, 2008 | RCA D52W19 52" Rear Projection Television
ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Dec 05, 2007 | Televison & Video
52 in RCA
The T.V. has no lamp, it has 3 guns red,blue,& green. Unplug the lead that goes to the high voltage splitter(make sure t.v. is unplug). Then turn the t.v. back on if you hear the H.V. lead making a hissing sound continuously most likely the h.v. block needs to be replaced. Follow the lead from the flyback to the h.v. splitter, this will be the lead that unplugs at the splitter.
Oct 11, 2007 | RCA P52926 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
