Question about Frigidaire GLTF1670A Front Load Washer
Tub won't move
Frigidaire GLTF1670A S0 Machine will fill with water and then do nothing. If you move the dial to spin the machine will drain. So the tub doesn't move at all. What is the problem?
    Genius:
  • 1,073 Answers
Could be motor, control board, motor controler
Posted on Apr 11, 2008
Won't spin fills and drains water if i manually turn dial
Direct drive or belt drive? If belt drive then thats easy, motor belt or pulley. Direct drive? motor, ,,, maybe.
Jan 11, 2012 | Frigidaire GLTF1240A Front Load Washer
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Mar 26, 2009 | Frigidaire GLTF1670A Front Load Washer
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Ftf530Es;Frigidaire front load washer
did you check the filter? If the filter is plugged in the least bit it won't allow machine to spin at high speeds
Mar 08, 2008 | Frigidaire GLTF1670A Front Load Washer
Washer won't drain
Well if you put your waste pipe to ground level whilst the machine has water in it (with the machine off ). If the water empties then yes your pump is bad. if not you have a blockage in the filter .
Although you said you cant see a blockage.
if you need any help dont hesitate to ask
Dec 27, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Front Loading Washer Leaking
there should be a rubber pipe going to the soap draw to the drum normally there's to pips one at the front of the machine and one on the top it is there have a good look in the machine make sure its un plugged be for putting your hands in the machine ok
Nov 28, 2007 | Frigidaire GLTF1670A Front Load Washer
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
May 07, 2006 | Indesit W 123 Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
135 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
