Question about Kicker ZX10001 Car Audio Amplifier
Kicker zx1500.1: no sound output
Here is what is up with the amp. I bought it from my friend and he said it worked fine. I hooked it up to my power cable and it lit up green and the red light never came on. I hooked it up to my subs (2 12" l7s), and they were powered but they gave out a long, constant tone. So I am not sure if it did that because I am not providing enough power, or if something is wrong with the internals.
Yes it does.
Posted on Apr 10, 2008
  • 631 Answers
Does it make the same noise if the RCA cables aren't plugged in?
How do I wire a kicker mono amp for my subwoofer to a kicker 4 channel amp that is already hooked up to run the 4 6x8 speakers
you should have an output on the amp running the 4 6/8's connect to kicker inputs hope you got a cap(capacitor)to run this set up and a good wiring kit.if so just run all the power cables to the power block feed the amps,ground them and don't forget the remote wire and you should be fine
Sep 23, 2014 | Car Audio & Video
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
I just bought a hifonics amp the brz2100.1D and when i tryed to hook it up every thing is correct as far as the wireing compared to the manual and the blue lights come on power light is on but its not...
MAKE SURE YOUR GROUND WIRE IS GROUNDED GOOD,,AND IT IS IMPORTENT TO HAVE YOUR REMOTE WIRE HOOKED UP. IT WILL BE A BLUE WIRE,,FIND THE HOT WIRE FOR YOUR TAIL LIGHTS AND HOOK IT THERE THEN WHEN YOU TURN YOUR CAR ON THE AMP WILL ALSO COME ON.THAT SHOULD STOP ALL THE NOISE AND POWER YOU UP.
Jul 15, 2011 | Hifonics BRZ21001D Car Amp
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
12" l5 no sound
Hi
maybe your voice coil is open circuit! or you have burn voice coil! thats why your unit is not functioning!
Thanks!!!!
Apr 30, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Car amplifers,,,,kicker amp's RCA jacks!
You could do a couple things if your head unit has all three outputs, then take them and hook them into the inputs. If you have just the front and the rear outputs, hook those to the inputs front and rear. Then hook the output of the 4 channel to the input of the mono block. I hope this helped
-Andrew Hawkins
Mar 28, 2008 | Audio Players & Recorders
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Car Audio & Video Logo
163 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
