Question about Acer TravelMate 2300 Notebook
Acer Travelmate 3200 usb dont work
Hi, I have an Acer Tracelmate 3201XCi and all of the usb's have gone off. I tried plugging in a memory stick and a power surge notice came up. Since then none of the usb sockets work. They still have power going to them as a small usb hoover works fine. Things I have tried so far:
I have reset the bios
I have re-installed Windows XP
I have Unistalled / reinstalled the USB Universal Host Controllers and updated them
I have unistalled / re-installed the USB hubs and updated them
I purchased a PCMCIA card with 4 USB slots on it. (When I put it into the PCMCIA slot the computer freezes until I remove it then the laptop goes OK again - It does try to install but freezes half way through the plug & play setup.)
I have also updated the chiset drivers from the Acer Site
I have tried the memory stick in other laptops and it works fine.
In Device manager the USB's are reported as working and all are enabled. In the USB hub properties however under the 'Power' tab I have a description of "2 Ports available" and "power Reqd" = 0mA - is this correct?
Please help as I'm pulling my hair out.
Thanks again
domp8
  • Anonymous Oct 13, 2008
    i have the same problem .its really annoying
Sir my name is ayaz ahmed  im  system administrator in quetta textile mills limited in karachi pakistan please solved my problem  thanks  best regard ayaz ahmed
Posted on Aug 20, 2008
    Sergeant:
    Champion:
  • 333 Answers
This may help - or not..
http://support.microsoft.com/?kbid=310575
If you have damaged the USB chip on the motherboard, you may be able to disable it in the BIOS. Then when you install your PCMCIA card it may work...
USB is not as tolerant of short circuits as RS232. I know I managed to destroy one of the ports on my m/b.! Using a Hoover may not be a good idea.
Posted on Apr 10, 2008
Ports on acer travelmate 4200 not working?
sounds like you may have driver for usb ports missing. check in device manager and see. if so simply reinstall drivers
Aug 12, 2012 | Acer TravelMate 4200 Series Laptop Charger...
My acer travelmate 250 wont start up whaen i switch it on its just a black screen and it bleeps 3 times then just knocks off
If you are getting beeps on startup and nothing shows on screen possibly the RAM of your system is gone bad.
You might try reseating the RAM to get this issue fixed, If you have more than 1 memory stick try loading one stick at a time to understand which of the RAM is gone bad.
Jul 15, 2010 | Acer TravelMate 240 Notebook
Acer Traverlmate 3260 no power
If it doesn't work off the battery either.
The connection inside the Pc has gone,
$150/$200 to be repaired.
Will be good then
Regards
Richard.
Apr 22, 2009 | Acer TravelMate 3260-4874 Notebook
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
Re: CAnnot find drivers for laptop
Hey Domp8
Check out the link below for the Wireless Drivers
http://www.driversdown.com/drivers/Acer-TravelMate-3200-Notebook-802.11b-g-Wireless-LAN-Driver_73064.shtml
and heres the LAN driver
http://www.driversdown.com/drivers/Acer-TravelMate-3200-Notebook-Broadcom-LAN-Driver_73062.shtml
Hope this helps,
djEnigma
Apr 01, 2008 | Computers & Internet
Bluetooth
maybe you just turned it off. try to turn on the switch. i think it is near the wifi switch or look for the bluetooth symbol on you laptop
Mar 30, 2008 | Acer TravelMate 6460-6752 (LXTED06059) PC...
Acer travelmate(belongs to my grandson), one rear usb three side mounted. Rear socket had been damaged, plastic contact support missing, pins touching case. Before I looked at it, notebook crashed if any...
motherboard dont have fuse has diodes which act similar to fuses but wont be blown.only things that will blow in that area are transistors or capacitors;but if these were blown usb's would not be detected.
in device manager were its says working correctly it relates to software istalled and working properly it cant tell u that the hub connection is damaged internally.
if your usb's are on card and connected to motherboard they can be replaced otherwise if built into motherboard youll have to take it to repair shop.
if the only problem is when u connect a usb device and not causing any other problems,u could use usb hubs that go into the pcmcia
Mar 30, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 230
yes they should do, the board should be backward compatable, as 2100 266mhz is hard to come by nowadays
Nov 23, 2007 | Acer TravelMate 2303LCi Notebook
Help i Have USB problems
try going into Control panel-administrative tools-computer management-disk manager Does it show up there? could be a problem with the memory sticks too: like unformatted state tried in another pc?
Sep 29, 2007 | Acer Aspire 5102WLMi Notebook
Computers & Internet Logo
372 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
