Question about Refrigerators
FRIDGE/FREEZER KEEPS FREZING UP
Freezer keeps freezing up have replaced heater element and thermo fuse but this did not work any help would be great
    Master:
  • 788 Answers
I would consider the thermostat sounds like the freezer thinks it's warmer than it actually is and keeps running.
Posted on Apr 10, 2008
    President:
  • 3,130 Answers
Did you check or replace the defrost timer? It could be a solid state type built onto a Printed Circuit board or could be a timer motor, it all depends on the model and make of the freezer.
Got a 9yr old w/house fridge/freezer model BJ504Q. Had the defrost heater element replaced 4 weeks ago While the heater works it is not it is not defrosting the upper part of the element which is still...
If you cleaned it of all frost and ice and it keeps doing this then perhaps the defrost thermostat is detached from where it should be or shutting off too early. Try replacing it if is attached well.
Oct 27, 2010 | Refrigerators
Fridge keeps freezing.
its not going into auto defrost the cause is either the freezer fan jammed or burned out the defrost timer but in 99% cases its a burnt out defrost element id start there replace it
Apr 20, 2010 | Hoover HCA390FFK Bottom Freezer...
My freezer coil keeps freezing up. I replaced the
In the freezer coil is a defrost heater coil, and a defrost thermostat. You have to expose the freezer coil to find them. If your local dealer can't get parts, I get mine from Repairclinic.com.
Apr 29, 2009 | Kenmore Refrigerators
Samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Apr 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
Feb 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Candy fridge freezer
check that the correct thermostat is installed and that the element wire is connected.check door rubber and door hinges.check if it has independant defrost timmers and if it is working.oh and see if the element is drawing current if fitted with one.
Nov 05, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer coils frozen and fridge not cold
check the thermo disc inside the freezer if the thermo disc working, check the heater tube either of thermo disc or heater bad
Sep 20, 2007 | Amana ARB1917CSR Bottom Freezer...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
