Question about Curtis-Mathis CM25011 25" TV
Curtis Mathis 25" tv 5 years old
My screen is black and the sound is on
    Master:
  • 788 Answers
How are you connected to your signal, is it cable, over the air, satelite? Did you check all the cables on the back of the TV? Does the menu of the TV come up on the screen or is that black too? If the menu doesn't come up then your tube or electronics or faulty, I would not repair a TV like this as a new similar TV is now $100 to $150.
Posted on Apr 10, 2008
  • Dean Joly
    Dean Joly Apr 10, 2008
    There is no bulb in this TV as it is a CRT.
  • 4,102 Answers
Hi this is common problem you will find the bulb needs replacing if you still have sound then it will be worth getting done
  • paul proctor Apr 10, 2008
    oh yes machine your right didnt look at the telly sorry mate follow machines advice as he hit the nail on the head sorry didnt realise what telly it was thanks Machine for pointing it out,
Tv_weight, curtis mathis 36 inch tube
Hello
The TV you specifies here [Curtis Mathis 36" picture tube type] has a weight of 150.3 lbs. OK.
Oct 19, 2011 | Televison & Video
There appears a solid black in the lower one third of the screen. What adjustment do I have to do?
It sounds like the captions for the hearing impaired is active, get remote and select menu, scroll down to captions, right arrow 1,2,3,4,off, make sure cursor is over off and press enter on your remote and should restore normal function to the set, some remotes have the caption button that is separate from the menu.
Mar 05, 2011 | Curtis-Mathis CM25011 25" TV
I have a universal remote control that I want to use with my Curtis Mathis TV. What code do I need to use to make the remote compatible with the TV?
Hello
Thee digit universal remote code for Curtis Mathis are:-
000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109
Four digit universal remote codes for Curtis Mathis are:-
0031 0105 0130
0004 0009 0000 0049
0109 0358 0001 0015
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jan 10, 2011 | Curtis-Mathis CM25011 25" TV
No sound
Check on the manual control on the tv itself Vol + - buttons see if functions normallyTry website like Remotes.com to buy a remote same as an exact original remote.
Jul 16, 2010 | Curtis-Mathis CM27101S TV
Lost code book need codes for curtis mathis and rca tv"s
need code for tv. lost booklet and cnt emember code
Jun 08, 2010 | Curtis-Mathis CM25011 25" TV
Curtis mathis tv takes to for picture to show after turning on
Look for a bad caps 250volt 2.2MF and a 25 volt 47MF near the horizontal deflection! And you may as well check the caps near the vertical IC as these are going bad...you have board out..you may as well do this. Then you will have a reconditoned TV with added years!
Feb 19, 2010 | Curtis-Mathis CM27101S TV
Lost color on curtis-mathis tv
CHECK FOR AND REDO LOOSE SOLDER JOINTS
Nov 20, 2008 | Curtis-Mathis Televison & Video
Your electron gun is failing. Throw it away!!!!!!!!
Mar 23, 2008 | Curtis-Mathis CM25011 25" TV
Television
Sometimes if the screen was affected by magnets it will fade. you could try placing magnets around the screen and moving them around, BEWARE you could make it worse. If it dosent fade youve had it........Sorry
Jan 22, 2008 | Curtis-Mathis CM25011 25" TV
1986 25 inch Curtis Mathis console tv
I have a curtis mathis console tv with a 8track player, casset player record player and a am/fm stereo, mod number on the box is F607 style TC2 seril number 04787814 new in the box never opened. where can i find out its value?
Nov 18, 2007 | Curtis-Mathis CM27101S TV
Curtis-Mathis CM25011 25" TV Logo
105 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Stan Skaggs
Stan Skaggs
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
