Recent problem with picture
Just recently my tv picture appears dull. The picture comes in fine but seems like the colors are off, sort of an overall greyish tint to the picture.
The first time I noticed this , I turned the TV off and later that day when I turned it on it was back to normal. However, a day later the same this has now happened again.
I hope this does not mean the plasma gas? life is over...I t has not even been 2 years yet! I
Would appreciate any suggestions or ideas.
  • Snacker May 12, 2008
    I have a similar problem. My 42pc3d is about 18 months old. In the last
    couple of weeks I have noticed a decrease in color brilliance, loss of
    sharpness, and overall dull display. The inputs are a Cox STB, and a
    Sony HT. Thinking maybe a power-off reset mght help, I pulled the power
    plugs on all. I returned power after a couple of minutes, but that
    seems to have no effect.
    Is there an internal color/display test that can be activated by a certain button pattern?
  • Anonymous Mar 22, 2014
    Just turns off and then right back on..only happens every so often, maybe once every couple,days. Seems like it might be some sort of interference
    Scholar:
  • 72 Answers
Plasma Tv panel only have a lifetime of 10000 hours. the phosphor inside the panel and the zenon, xenon gas only will last so long . Pretty much like a florescent light bulb.
Posted on May 03, 2008
Philips 60PP9363 colors not right. TV is 5 years old, the convergence appears to be fine in that all of the colors line up fine, but they are not the right shade. The green and blue are both teal, with...
Ur tv look dull in pictures?Ur tv might need it CRT tube coolant replacement.Tries websites like Tvrepairworld.com,Tvrepairkit.com to buy a coolant kit to replaced CRT tube coolant replacement.
Aug 04, 2010 | Philips 60PP9363 60" Rear Projection...
Ilo 42" Wide Screen LCD TV...Picture Malfunction
From some of the forum threads I've read about this, it seems like there were early issues due to bad firmware, but they have all be resolved with the recent updates. It also appears to be very easy to replace the hard drive. Just swap it out, format from the menu and you are done.
u will neeed to get it updated
Jan 25, 2008 | iLO 3200 32 in. LCD Television
Sony 60" HDTV Plasma WEGA....Picture Problem
My guess is that you're not missing the color it just appears muted... That problem is a common one in both the 50 and 60 inch models. And if you change video mode with nothing hooked up you'll see a faint color where none should be...
That's simply dust in the optical block on one of either the red, blue or green lcd panel. Wipe it down with a non-linting cloth and a "light" amount of windex and you're back in business...
But check it out by switchin through the video modes with nothing hooked up.. The faint color you see if the lcd panel that's having the most problem and the one that's muting your green.
Bill
Nov 10, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Blues' appear more green
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 05, 2010 | Philips Televison & Video
Screen Out of Focus with Wavy Lines - Perfect Focus Will Not Corr
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Dark greys appear a dull green.
could be a jumper that needs to be removed on the DMD board, or a setting in the factory mode, mute-182-power will get you in there
Jul 11, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Hitachi 43fdx20b
well i had the same t.v. and u will have to set the picture tube which is really simple it ight seem hard but if you need an hand give me an call 1-403-362-2560 and ask for jason
Dec 17, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Color Fading
check your menu settings if not there then you may require board level service.or eprom sub menu adjustment.
Dec 02, 2006 | Panasonic PT-47WX42 47" Rear Projection...
Sounds like your component cables may have come off its contact point. Check to see if your cables have become loose. Pushing them back in place should take care of that but check at the source output and the TV's input. Red Green Blue, when ever one of these 3 come out of contact the TV will produce a color hue relevant to what color remains in contact, looking faint and discolored. If you do find a loose cable connection, inspect the contact ends and squeeze lightly to restore a snug fit but don't do it to hard or you may damage the prongs.
Oct 22, 2006 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
